[postgis-users] Re: Testing for empty feature
Sean Fulton seanasy at gmail.com
Sun Jul 6 13:43:52 PDT 2008
ST_IsEmpty doesn't seem to work for me and I don't see the MultiPolygon
being converted to a GeometryCollection.
civics=# SELECT astext(wkb_geometry) FROM scale150000 LIMIT 1;
         astext
 MULTIPOLYGON(( EMPTY))
(1 row)
civics=# SELECT ST_IsEmpty(wkb_geometry) FROM scale150000 LIMIT 1;
 st_isempty
 f
(1 row)
ST_NPOINTS works. It seems like there should be a more direct way.
	Sean
On 2008-07-04 12:03:33 -0400, Martin Davis <mbdavis at refractions.net> said:
> Actually JTS/GEOS handle empty MultiPolygons just fine. I don't know why
> the MULTIPOLYGON EMPTY is being converted to a general
> GeometryCollection - I think this must be something that is being done
> by PostGIS.
> Seems like the answer is to use ST_IsEmpty. Doing text comparisons is
> always going to be risky.
> Kevin Neufeld wrote:
>> I believe that an empty multipolygon is converted into an empty
>> geometrycollection in JTS and hence PostGIS.
>> postgis=# SELECT ST_AsText('MULTIPOLYGON EMPTY'::geometry);
>> st_astext
>> GEOMETRYCOLLECTION EMPTY
>> (1 row)
>> postgis=# SELECT ST_IsEmpty('MULTIPOLYGON EMPTY'::geometry);
>> st_isempty
>> t
>> (1 row)
>> Alternatively, I suppose you could get the number of points in the geometry.
>> postgis=# SELECT ST_NPoints('MULTIPOLYGON EMPTY'::geometry);
>> st_npoints
>> 0
>> (1 row)
>> Cheers,
>> Kevin
>> Sean Fulton wrote:
>>> How do I test for an empty feature such as 'MULTIPOLYGON(( EMPTY ))' ?
>>> IsEmpty seems to work only for collections.
>>> astext(wkb_geometry) = 'MULTIPOLYGON(( EMPTY ))' doesn't seem to work.
>>> Thanks,
>>> Sean
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
