[postgis-users] Transform overlapping polygons to non-overlapping?
Brent Fraser bfraser at geoanalytic.com
Fri Jul 11 14:18:39 PDT 2008
Regina,
  The "SELECT MAX..." query didn't work on my sub-set of 12800 polygons.  It created 12643 polygons some of which overlap (I expected more, not less, than the original).
  I may try converting to linestrings, creating one "minimum bounding rectangle" for the entire dataset, then doing an intersect of the lines with the MBR.  In my case this would be ok as there are not attributes on the polygons yet.
Thanks!
Brent
Obe, Regina wrote:
> Brent,
> I guess it really depends on how exactly you want to achieve
> non-overlapping.
> If for example you are basing it on some sort of attribute and all your
> overlapping polygons are valid
> Then a simple
> SELECT ST_Union(the_geom) As newgeom, field1
> FROM sometable
> GROUP BY field1
> I think will guarantee non-overlapping polygons because as part of the
> process of ST_Union - it would irradicate the overlapping regions to
> just create one.  That is part of the reason why its so much slower than
> ST_Collect for example.
> For your exact case below - you would union all the overlapping polygons
> together which could be really slow depending on how many overlap. The
> query I would write to achieve that would be something like this
> SELECT MAX(a.gid) As newgid, ST_Union(a.the_geom) As the_geom
> FROM poly a
> GROUP BY (SELECT MAX(r.gid) FROM poly r
>    WHERE (a.gid = r.gid OR ST_Overlaps(r.the_geom, a.the_geom)));
> Hope that helps,
> Regina
> *From:* postgis-users-bounces at postgis.refractions.net on behalf of Brent
> Fraser
> *Sent:* Fri 7/11/2008 12:14 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Transform overlapping polygons to
> non-overlapping?
> To All,
>   There doesn't seem to be an obvious answer to the problem given below
> (aka cleaning polygons, creating planar polygons, etc).  I did see a
> note on the PostGIS wiki wishlist to "Add a geometry cleaner". There is
> also a suggestion to convert to linestrings, node, then polygonize
> (while that may work for a small set of polygons, I've got 1.1 million
> to clean).  JTS, Geos, etc will likely fail due to the large number of
> polygons so I'll need a different approach.
>   I'm considering writing some code to iterate through my table of
> polygons, cleaning a small subset at a time.  I think using PostGIS for
> the geometry storage and spatial query/selection makes sense.  Any
> suggestions on which API to use?
>         GDAL's OGR
>         PostgreSQL's libpq
>         other?
> Thanks!
> Brent Fraser
> Brent Fraser wrote:
>>  PostGIS'ers,
>>  I've got a table of overlapping polygons.  How can I make it a table of
>>  non-overlapping polygons?
>>  For example, if table "polys2" contains two polygons A1 and B1 which
>>  overlap.  I'd like to create table "polys3" with polygons A2, B2, C2,
>>  where C2 is the overlap region of A1 and B1, and A2 = A1 - C2, and B2 =
>>  B1 - C2.
>>  Looking at the overlay operations in the JTS doc it looks like doing an
>>  Intersection (to get only the overlapping area) then adding the
>>  Symmetric Difference (to get the non-overlapping areas) might work.
>>  Am I on the right track or is there an easier way (since all the
>>  polygons are in one table)?
>>  Thanks!
>>  Brent Fraser
>>  _______________________________________________
>>  postgis-users mailing list
>>  postgis-users at postgis.refractions.net
>>  http://postgis.refractions.net/mailman/listinfo/postgis-users
> * The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant
> to Massachusetts law. It is intended solely for the addressee. If you
> received this in error, please contact the sender and delete the
> material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
