[postgis-users] Postgis to ESRI shape file encoding problem
Maher_Karim at dorsch.com.jo Maher_Karim at dorsch.com.jo
Mon Jul 21 04:48:20 PDT 2008
Hello,
You have an error in this sentence, you should use it like this
ALTER DATABASE DBIPRS SET client_encoding=latin2;
Regards
Maher
Ervin Ramonllari <ervin.ramonllari at hotmail.com>
Sent by: postgis-users-bounces at postgis.refractions.net
07/21/2008 01:33 PM
Please respond to PostGIS Users Discussion
        To:     PostGIS Users Discussion
<postgis-users at postgis.refractions.net>
        cc:
        Subject:        RE: [postgis-users] Postgis to ESRI shape file
encoding problem
I tried this way :
ALTER DATABASE DBIPRS SET PGCLIENTENCODING to 'Latin2'
but i got the error:
ERROR: unrecognized configuration parameter "pgclientencoding"
SQL state: 42704
> Date: Sat, 19 Jul 2008 14:37:37 +0200
> From: sdteffen at gmail.com
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] Postgis to ESRI shape file encoding problem
> You can also try to set the environment variable PGCLIENTENCODING to the
> encoding value you need (e.g. LATIN2).
> Steffen
> >> I'm trying to export some data from a Postgresql database encoded in
UTF-8
> >> into some ESRI shape files.
> >> I'm using PostGIS Dumper (pgsql2shp).
> postgis-users mailing list
Discover the new Windows Vista Learn more!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080721/1a630bd3/attachment.html>
