[postgis-users] create tables smarter
Chris Hermansen chris.hermansen at timberline.ca
Wed Jun 4 15:26:14 PDT 2008
"try and see", those are words I like.
But first I googled, and I saw past discussions of the futility of
trying to create triggers on systems tables.
However, nothing I saw indicated I couldn't create a rule on a systems
table, so I decided to try it.
First, I decided to do a straightforward experiment to ensure myself
that I more or less understood PostgreSQL rules.
I created two tables, one called "data", one called "tracks", and a rule
that was triggered every time a row was inserted into "data", noting
that insertion in "tracks":
    clh=# create table data (item text, qty integer);
    CREATE TABLE
    clh=# create table tracks (item text);
    CREATE TABLE
    clh=# create rule table_rule as on insert to data do also
    clh-# insert into tracks values (new.item);
    CREATE RULE
    clh=# insert into data values ('software',37);
    INSERT 0 1
    clh=# insert into data values ('bullets', 2339);
    INSERT 0 1
    clh=# insert into data values ('gin',64556);
    INSERT 0 1
    clh=# select * from data;
       item   |  qty
     software |    37
     bullets  |  2339
     gin      | 64556
    (3 rows)
    clh=# select * from tracks;
       item
     software
     bullets
     gin
    (3 rows)
    clh=#
OK, so far, so good.  Let's try the same thing with pg_tables:
    clh=# drop rule table_rule on data;
    DROP RULE
    clh=# drop table tracks;
    DROP TABLE
    clh=# drop table data;
    DROP TABLE
    clh=# create table tracks (tablename name);
    CREATE TABLE
    clh=# create rule table_rule as on insert to pg_tables do also
    insert into tracks values (new.tablename);
    CREATE RULE
    clh=# create table fink (a int, b text);
    CREATE TABLE
    clh=# create table zink (c float, d date);
    CREATE TABLE
     tablename
    (0 rows)
    clh=#
Well, so much for that idea.  We can create rules on system tables, they
just don't work.
Bummer.
Paul Ramsey wrote:
> Triggers on system tables aren't allowed, try and see.  I like that
> GEOMETRY_COLUMNS provides a visible and standard way for 3rd party
> apps to understand the geometry in the database, and I hate having to
> maintain it. I've been wanting to make it magical for many years.
> There's other ways to do it, of course. My favorite stop-gap idea is
> to add some code to the hooks called by ANALYZE to update the
> GEOMETRY_COLUMNS table at the same time.  That way pg_autovacuum would
> occasionally update it in the background, so if things went out of
> synch due to users changing things, they'd come back again in a bit.
> P
> On Wed, Jun 4, 2008 at 1:40 PM, Chris Hermansen
> <chris.hermansen at timberline.ca> wrote:
>> Paul says "the maintenance of GEOMETRY_COLUMNS has been a longstanding
>> bug'a'bear"...
>> Why don't I find that surprising :-)
>> But anyway, Paul also says that triggers on system tables could have
>> been used.  And I guess that makes me wonder, is there anything to stop
>> a person from putting triggers on system tables in PostgreSQL?  Does
>> that cause a problem somewhere else down the line?
>> Paul Ramsey wrote:
>>> Trust me, Chris, the maintenance of GEOMETRY_COLUMNS has been a
>>> longstanding bug'a'bear and in retrospect we probably would have been
>>> better off without it.  In order to get an automagic GEOMETRY_COLUMNS
>>> though, we either required (a) triggers on system tables or (b)
>>> parameterized user-defined types.  And now it looks like we'll have
>>> (b) in 8.4, so we can start to create our magic GEOMETRY_COLUMNS
>>> table.
>>> P
>>> On Wed, Jun 4, 2008 at 1:18 PM, Chris Hermansen
>>>> Hi Frank, folks;
>>>> This is the kind of thing that would be really great to see:
>>>>    * a way of creating geometry that relied on SQL and not on calling
>>>>      stored procedures
>>>>    * a way of deleting same
>>>>    * a system table that held ancilliary information
>>>> It bugs me that I can DROP a table and still have a row referring to
>>>> that table in geometry_columns.
>>>> I also find it kind of perverse that some desktop viewers require a
>>>> specific structure in a table containing geometry in order to view it.
>>>> Not to sound negative or anything!  Heaven forfend!  It's just that
>>>> PostGIS is so much better than having to use a programmatic access like
>>>> SDE when I want to use my geometry, that I find it hard to accept that
>>>> it hasn't gone that last few centimetres.
>>>> Frank Warmerdam wrote:
>>>>> Lee Hachadoorian wrote:
>>>>>> Andreas,
>>>>>> AddGeometryColumn does two things: it adds a column of type geometry,
>>>>>> and it adds a row to table geometry_columns.  If I understand what it
>>>>>> is you want to do, you can do the SELECT and then add the row to
>>>>>> geometry_columns with an INSERT statement:
>>>>> Folks,
>>>>> I did a presentation at PGCon and the issue of AddGeometryColumn() being
>>>>> necessary to populate the geometry_columns table came up.  Some of the
>>>>> postgres techies suggested there has been work so that extension defined
>>>>> types could actually take extra arguments when used in the CREATE TABLE
>>>>> statement and that this might let us avoid the need to use
>>>>> AddGeometryColumn().
>>>>> ie.
>>>>> CREATE TABLE ROADS
>>>>>   (id   INT,
>>>>>    name VARCHAR(255),
>>>>>    geom GEOMETRY(<dimension>,<srid>,<type>) )
>>>>> Then the callback for the GEOMETRY type would take care of extending the
>>>>> geometry_columns table, presumably picking up the schema, table and
>>>>> column
>>>>> name from the context.
>>>>> In an ideal world, the dimension, srid and type would even show up when
>>>>> you describe the table, and would be automatically propagated to new
>>>>> tables
>>>>> created from a select.
>>>>> I don't know how hard this is, or if I overestimated how these custom
>>>>> type
>>>>> definition parsers work but I think it would be an appealing direction of
>>>>> development for postgis.
>>>>> Forgive me if I'm stating something already well understand in the
>>>>> postgis
>>>>> community.  I'm a bit of a diletante in this world. :-)
>>>>> Best regards,
>>>> Regards,
>>>> Chris Hermansen         mailto:chris.hermansen at timberline.ca
>>>> tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
>>>> Timberline Natural Resource Group · http://www.timberline.ca
>>>> 401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Regards,
Regards,
