[postgis-users] create tables smarter
Kevin Neufeld kneufeld at refractions.net
Wed Jun 4 15:38:39 PDT 2008
Chris Hermansen wrote:
> OK, so far, so good.  Let's try the same thing with pg_tables:
>     clh=# drop rule table_rule on data;
>     DROP RULE
>     clh=# drop table tracks;
>     DROP TABLE
>     clh=# drop table data;
>     DROP TABLE
>     clh=# create table tracks (tablename name);
>     CREATE TABLE
>     clh=# create rule table_rule as on insert to pg_tables do also
>     insert into tracks values (new.tablename);
>     CREATE RULE
>     clh=# create table fink (a int, b text);
>     CREATE TABLE
>     clh=# create table zink (c float, d date);
>     CREATE TABLE
>     clh=# select * from tracks;
>      tablename
>     (0 rows)
>     clh=#
> Well, so much for that idea.  We can create rules on system tables, they
> just don't work.
> Bummer.
Just thought I'd point out Chris that pg_tables is a view, not a system
table.  For kicks, try your rule on pg_class.
-- Kevin
