[postgis-users] Topological Exceptions
Obe, Regina robe.dnd at cityofboston.gov
Tue Mar 11 04:49:45 PDT 2008
I've been doing a lot of work using ST_Intersection, ST_Difference,
ST_Union etc to cut out slices of geometries I don't want and slicing up
geometries into smaller pieces, reunioning etc.
I've been running into a lot of Topological Exceptions of the form
directed Edge this and non-noded that.  For the most part I've been able
to overcome these by slicing things smaller or skipping over problem
regions (e.g. areas where the difference is a line or point or something
of that sort).
I think a lot of people have run into the same issues and have gotten
frustrated and there doesn't seem to be a simple solution suggested to
overcome these.
Is there any way we can change (add overloaded functions or some setting
parameter) - that take additional parameters to simply ignore these
errors that says return empty collection or NULL when a GEOS error is
thrown.  That way I can simply ignore these and throw them out of my
equation and move on.
Just a thought.  I'm sure my suggestion is rather simple-minded and I'm
sure I'm missing some reason of why this is not feasible.  An
explanation of why my suggestion is stupid at anyrate would be nice.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080311/4bfbc6df/attachment.html>
