[postgis-users] Having problemas to convert SHP to PGSQL
George R. C. Silva georger.silva at gmail.com
Wed May 14 11:27:28 PDT 2008
hello all!
Once again i come with a issue for you the experts :P
I´m having trouble converting a shapefile to postgis schema, and nothing
will make it work.
the shp2pgsql actually runs, but at the end, no table is added or
populated. I even tried converting using QGIS 10
I will attach a zip of the shpfile. SRID is 29182.
Ive checked within ArcGIS is the shp is valid, or has problems, and nothing.
My postgresql is 8.3 and latest pgis.
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080514/b01af67f/attachment.obj>
