[postgis-users] Having problemas to convert SHP to PGSQL
George Silva georger.silva at gmail.com
Wed May 14 20:03:32 PDT 2008
Thanks Robert. Will try that.
What should i look for?
George
On Wed, May 14, 2008 at 3:45 PM, Burgholzer,Robert <
rwburgholzer at deq.virginia.gov> wrote:
> BTW - I always dump the output of shp2pgsql to a text file, so that I can
> look at the SQL insert statements if there is a problem.
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> 804-698-4405
> Open Source Modeling Tools:
> http://sourceforge.net/projects/npsource/
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Burgholzer,Robert
> Sent: Wednesday, May 14, 2008 2:36 PM
> To: PostGIS Users Discussion
>  Subject: RE: [postgis-users] Having problemas to convert SHP to PGSQL
> Syntax for command please ...
> 804-698-4405
> postgis-users-bounces at postgis.refractions.net] On Behalf Of George R. C.
> Silva
> Sent: Wednesday, May 14, 2008 2:27 PM
> Subject: [postgis-users] Having problemas to convert SHP to PGSQL
> hello all!
> Once again i come with a issue for you the experts :P
> I´m having trouble converting a shapefile to postgis schema, and nothing
> will make it work.
> the shp2pgsql actually runs, but at the end, no table is added or
> populated. I even tried converting using QGIS 10
> I will attach a zip of the shpfile. SRID is 29182.
> Ive checked within ArcGIS is the shp is valid, or has problems, and
> nothing.
> My postgresql is 8.3 and latest pgis.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080515/4640f0bd/attachment.html>
