[postgis-users] Topology and Triggers
Webb Sprague webb.sprague at gmail.com
Thu May 15 20:24:37 PDT 2008
> At
> this moment i will try a Topology trigger that will delete the overlaping
> part of digitized polygon.
I would write the function that does the deleting separately from the
trigger (which would just call it).  It could be useful all by itself.
IF you get the function to work well, could  you send to the list?
If we could get a bunch of such functions operational, the next step
would be to use them with a set of topology constraints like with the
coverage model etc.
