[postgis-users] finding duplicate value for the_geom field
Obe, Regina robe.dnd at cityofboston.gov
Tue May 27 05:49:15 PDT 2008
I guess since everyone else is giving their suggestions I might as well
give one too
SELECT the_geom, min(gid) as min_gid, max(gid) as max_gid, COUNT(gid) as
numdupes
FROM sometable
GROUP BY the_geom
HAVING COUNT(gid) > 1
Note that the above query is a bit flawed since I think when you do a
group by on the_geom it actually does a group by on the bounding box
(not the geometry) and returns the first geometry.
I could be wrong though, but that is my understanding.
If you only have 2 dupes, min_gid and max_gid will return the potential
dupes
then you can compare them with a
g1.the_geom = g2.the_geom  (I think does a binary compare)
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Antonio Di Marco
Sent: Tuesday, May 27, 2008 7:57 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] finding duplicate value for the_geom field
Hi, how can I find duplicate value in a PostgreSQL table for the
geometry field (the_geom)
Thanks a lot
Antonio
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
