[postgis-users] Roadmap for next major release of PostGIS
Chris Hermansen chris.hermansen at timberline.ca
Wed May 28 10:19:05 PDT 2008
Sorry, one other thing:
Mark Cave-Ayland wrote:
>> It would be nice if Proj and GEOS dependencies also suggested to the
>> builder that the latest version should be used...
> The current test code has full version checking for both GEOS and
> PROJ, so please provide technical reasons as to which minimum versions
> should be supported. From a purely selfish point of view, I'd be
> tempted to make the minimum version of PROJ 4.5.0 since earlier
> versions don't contain the right datum for correct OSGB transformations.
Maybe (probably) I wasn't clear enough here.  I'm running Ubuntu 8.04.
The current versions in the repositories are:
PostGIS 1.3.3
Proj 4.6.0
Geos 2.2.3
PostgreSQL 8.3.1 (there's an 8.2 there as well)
I'm sad to see that a newer version of GEOS didn't make it to 8.04.  I
boldly assume that this is an easily-understood slip-up on the part of
the upstream folk that could have been averted had PostGIS refused to
build against (or at least complained about) Geos 2.2.x
If I'm wrong in my assumption - heck, maybe there are good reasons to
prefer Geos 2.2.x against the most up to date release - please feel free
to chastise me firmly!
Chris Hermansen         mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
