[postgis-users] Postgis problem : Can not compile the code successful
Kevin Neufeld kneufeld at refractions.net
Tue Oct 21 08:35:14 PDT 2008
Yeah, I was never fond of the postgis driver myself.  Someday we'll have
to revisit that.
I use JTS rather than PGgeometry to read and write JTS Geometry objects
... works very well.
http://postgis.refractions.net/pipermail/postgis-users/2007-March/014911.html
Cheers,
Kevin
John wrote:
>    My name is john, this day i have some problem about Postgis,
>    I have readed Postgis Documentation, and try to compile source code.
>    I am using Postgresql 8.2.10 version,and using the computer
> language's java.
>    I use the JDK 1.5 and Tomcat 6.0.
>    In postgis-1.3.3.pdf source code is:
>       4.8 Java Clients (JDBC)
>     import java.sql.*;
>     import java.util.*;
>     import java.lang.*;
>     import org.postgis.*;
>     public class JavaGIS {
>     public static void main(String[] args) {
>     java.sql.Connection conn;
>         try {
>     * Load the JDBC driver and establish a connection.
>     ClassforName("org.postgresql.Driver");
>     String url = "jdbc:postgresql://localhost:5432/database";
>     conn = DriverManager.getConnection(url, "postgres", "");
>     * Add the geometry types to the connection. Note that you
>     * must cast the connection to the pgsql-specific connection
>     * implementation before calling the addDataType() method.
>     ((org.postgresql.Connection)conn).addDataType("geometry","org.postgis.PGgeometry");
>     ((org.postgresql.Connection)conn).addDataType("box3d","org.postgis.PGbox3d");
>     * Create a statement and execute a select query.
>     Statement s = conn.createStatement();
>     ResultSet r = s.executeQuery("select AsText(geom) as geom,id from
>     geomtable");
>     while( r.next() ) {
>     * Retrieve the geometry as an object then cast it to the geometry type.
>     * Print things out.
>     PGgeometry geom = (PGgeometry)r.getObject(1);
>     int id = r.getInt(2);
>     System.out.println("Row " + id + ":");
>     System.out.println(geom.toString());
>     s.close();
>     conn.close();
>     catch( Exception e ) {
>     e.printStackTrace();
>     I can not compile this code successful, always report wrong .
>     can you help me, send the right code to my email.
>                                  Thanks
>                                          john
> [¹ã¸æ] ½ðÇï×î¹Øע¥ÅÌ-·¿²»Ê¤·¿
> <http://popme.163.com/link/003985_1010_7027.html>
> postgis-users mailing list
