Thank you mailto me. Re: [postgis-users] Postgis problem : Can not compile the code successful
John john123apple at 163.com
Tue Oct 21 23:47:56 PDT 2008
 Hello Kevin:
       Thanks you send message to me, these days I solve one problem;
       In Postgis DOCUMENTATION,the source code is:
      ((org.postgresql.Connection)conn).addDataType("geometry","org.postgis.PGgeometry");
       the right code is:
        ((org.psotgresql.jdbc3.Jdbc3Connection)conn).addDataType ("geometry","org.postgis.PGgeometry");
     I seek the postgresql.jar and postgis-1.3.3.jar.
     But another problem is appeared.
     The code is:
          PGgeometry geom = (PGgeometry)r.getObject(1);
          System.out.println(geom.toString());
     But I do not know how to solve the problem.
     I use the computer language is jsp+Tomcat6.0 +JDK1.5.
    Cheers,
    john
在2008-10-21,"Kevin Neufeld" <kneufeld at refractions.net> 写道:
>Yeah, I was never fond of the postgis driver myself.  Someday we'll have
>to revisit that.
>I use JTS rather than PGgeometry to read and write JTS Geometry objects
>... works very well.
>http://postgis.refractions.net/pipermail/postgis-users/2007-March/014911.html
>Cheers,
>Kevin
>John wrote:
>>    My name is john, this day i have some problem about Postgis,
>>    I have readed Postgis Documentation, and try to compile source code.
>>    I am using Postgresql 8.2.10 version,and using the computer
>> language's java.
>>    I use the JDK 1.5 and Tomcat 6.0.
>>    In postgis-1.3.3.pdf source code is:
>>       4.8 Java Clients (JDBC)
>>     import java.sql.*;
>>     import java.util.*;
>>     import java.lang.*;
>>     import org.postgis.*;
>>     public class JavaGIS {
>>     public static void main(String[] args) {
>>     java.sql.Connection conn;
>>         try {
>>     * Load the JDBC driver and establish a connection.
>>     ClassforName("org.postgresql.Driver");
>>     String url = "jdbc:postgresql://localhost:5432/database";
>>     conn = DriverManager.getConnection(url, "postgres", "");
>>     * Add the geometry types to the connection. Note that you
>>     * must cast the connection to the pgsql-specific connection
>>     * implementation before calling the addDataType() method.
>>     ((org.postgresql.Connection)conn).addDataType("box3d","org.postgis.PGbox3d");
>>     * Create a statement and execute a select query.
>>     Statement s = conn.createStatement();
>>     ResultSet r = s.executeQuery("select AsText(geom) as geom,id from
>>     geomtable");
>>     while( r.next() ) {
>>     * Retrieve the geometry as an object then cast it to the geometry type.
>>     * Print things out.
>>     int id = r.getInt(2);
>>     System.out.println("Row " + id + ":");
>>     s.close();
>>     conn.close();
>>     catch( Exception e ) {
>>     e.printStackTrace();
>>     I can not compile this code successful, always report wrong .
>>     can you help me, send the right code to my email.
>>                                  Thanks
>>                                          john
>> [广告] 金秋最关注楼盘-房不胜房
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081022/35917766/attachment.html>
