[postgis-users] Can not compile the source code of Postgis successful
John john123apple at 163.com
Thu Oct 23 00:10:51 PDT 2008
   My name is john, this day i have some problem about Postgis,
   I have readed Postgis Documentation, and try to compile source code.
   I am using Postgresql 8.2.10 version,and using the computer language's java.
   I use the JDK 1.5 and Tomcat 6.0.
   In postgis-1.3.3.pdf source code is:
  4.8 Java Clients (JDBC)
import java.sql.*;
import java.util.*;
import java.lang.*;
import org.postgis.*;
public class JavaGIS {
public static void main(String[] args) {
java.sql.Connection conn;
    try {
* Load the JDBC driver and establish a connection.
ClassforName("org.postgresql.Driver");
String url = "jdbc:postgresql://localhost:5432/database";
conn = DriverManager.getConnection(url, "postgres", "");
* Add the geometry types to the connection. Note that you
* must cast the connection to the pgsql-specific connection
* implementation before calling the addDataType() method.
((org.postgresql.Connection)conn).addDataType("geometry","org.postgis.PGgeometry");
((org.postgresql.Connection)conn).addDataType("box3d","org.postgis.PGbox3d");
* Create a statement and execute a select query.
Statement s = conn.createStatement();
ResultSet r = s.executeQuery("select AsText(geom) as geom,id from geomtable");
while( r.next() ) {
* Retrieve the geometry as an object then cast it to the geometry type.
* Print things out.
PGgeometry geom = (PGgeometry)r.getObject(1);
int id = r.getInt(2);
System.out.println("Row " + id + ":");
System.out.println(geom.toString());
s.close();
conn.close();
catch( Exception e ) {
e.printStackTrace();
I can not compile this code successful, always report wrong .
can you help me, send the right code to my email.
[广告] 金秋最关注楼盘-房不胜房
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081023/aa9f796c/attachment.html>
