[postgis-users] PostGIS topology
Mark Leslie mrk.leslie at gmail.com
Sun Sep 21 20:16:51 PDT 2008
In that case, Daniel was on the right track suggesting pgRouting
(http://pgrouting.postlbs.org/).  It extends PostGIS for just this sort
of purpose and will likely be easier than using GEOS directly.
Unfortunately, I'm no expert on pgRouting, but their website should be
worth a look.
Mark Leslie
Nandorov wrote:
> i have some network data in CAD and i want to save it in a geospatial
> database. My choice was postgis. Now, i want to create a topology, like in
> CAD, to have functionality like "the shortest path" and stuff like that. I
> dont know if postgis gives a tool to build a topology (nodes, linkers,
> edges) with ur geospatial data. thanks
> best regards
> mchapman wrote:
>> I use geos directly on windows xp using visual studio 2005.  How do you
>> plan to use it?
>> Martin
>> ------Original Message------
>> From: Mark Leslie
>> Sender: postgis-users-bounces at postgis.refractions.net
>> To: PostGIS Users Discussion
>> ReplyTo: PostGIS Users Discussion
>> Sent: Sep 21, 2008 5:33 PM
>> Subject: Re: [postgis-users] PostGIS topology
>> Nandorov wrote:
>>> Hello,
>>> Thanks for your replies.  i read the info in
>>> http://postgis.com/support/wiki/index.php?PostgisTopology
>>> Mark, have you worked with GEOS before? I'm going to use windows
>>> enviroment
>>> and i guess i have to build my own installer.(I found GEOS for Linux and
>>> API's for a windows build) it's GEOS a good choice? and how does it works
>>> exactly? thanks
>>> best regards
>> I haven't worked directly in GEOS much at all.  Before you go the route
>> of building on Windows, what exactly are you trying to do?
>> Mark Leslie
>> Geospatial Software Architect
>> LISAsoft
>> Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
>> Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
>> LISAsoft is part of the A2end Group of Companies
>> http://www.ardec.com.au
>> http://www.lisasoft.com
>> http://www.terrapages.com
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Sent via BlackBerry by AT&T
