[postgis-users] PostGIS topology
Nandorov nandorov at gmail.com
Mon Sep 22 10:45:15 PDT 2008
Ok, thanks. I'm going to try PgRouting. If someone of you, guys, already
worked with PgRouting, any help will be well received :-D
Mark Leslie-3 wrote:
> In that case, Daniel was on the right track suggesting pgRouting
> (http://pgrouting.postlbs.org/).  It extends PostGIS for just this sort
> of purpose and will likely be easier than using GEOS directly.
> Unfortunately, I'm no expert on pgRouting, but their website should be
> worth a look.
> Mark Leslie
> Nandorov wrote:
>> i have some network data in CAD and i want to save it in a geospatial
>> database. My choice was postgis. Now, i want to create a topology, like
>> in
>> CAD, to have functionality like "the shortest path" and stuff like that.
>> I
>> dont know if postgis gives a tool to build a topology (nodes, linkers,
>> edges) with ur geospatial data. thanks
>> best regards
>> mchapman wrote:
>>> I use geos directly on windows xp using visual studio 2005.  How do you
>>> plan to use it?
>>> Martin
>>> ------Original Message------
>>> From: Mark Leslie
>>> Sender: postgis-users-bounces at postgis.refractions.net
>>> To: PostGIS Users Discussion
>>> ReplyTo: PostGIS Users Discussion
>>> Sent: Sep 21, 2008 5:33 PM
>>> Subject: Re: [postgis-users] PostGIS topology
>>> Nandorov wrote:
>>>> Hello,
>>>> Thanks for your replies.  i read the info in
>>>> http://postgis.com/support/wiki/index.php?PostgisTopology
>>>> Mark, have you worked with GEOS before? I'm going to use windows
>>>> enviroment
>>>> and i guess i have to build my own installer.(I found GEOS for Linux
>>>> and
>>>> API's for a windows build) it's GEOS a good choice? and how does it
>>>> works
>>>> exactly? thanks
>>>> best regards
>>> I haven't worked directly in GEOS much at all.  Before you go the route
>>> of building on Windows, what exactly are you trying to do?
>>> Mark Leslie
>>> Geospatial Software Architect
>>> LISAsoft
>>> Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
>>> Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
>>> LISAsoft is part of the A2end Group of Companies
>>> http://www.ardec.com.au
>>> http://www.lisasoft.com
>>> http://www.terrapages.com
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> Sent via BlackBerry by AT&T
View this message in context: http://www.nabble.com/PostGIS-topology-tp19560868p19613060.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
