[postgis-users] Bug Converting from WGS 84 to UTM ?
Paul Ramsey pramsey at cleverelephant.ca
Mon Sep 29 20:54:30 PDT 2008
Use 26910.
The reference you chose is for the southern hemisphere (hence the "S").
P
On Mon, Sep 29, 2008 at 7:55 PM, Oliver Monson <monson36 at gmail.com> wrote:
> Hi All,
> I'm not sure if I'm seeing some random bug, or just not doing/understanding
> something correctly?
> I have a list of point geometries in a table (WGS 84 SRID=4326). I wanted to
> extract the UTM coordinates for these points, so I chose SRID= 32710, which
> has the description PROJCS["WGS 84 / UTM zone 10S..." since my points were
> in Northern California. I perform my select statement which looks something
> like this:
> SELECT x(ST_Transform(geometry,32710)), y(ST_Transform(geometry,32710))
> FROM point_table
> But the results seem strange. Doing a quick check vs the UTM coordinates in
> Google Earth, I see theres this extra "1" in front of all of my Northing
> values.
> Here's an example:
> Lon -122.3888235, Lat 37.7729709 transforms to --> 553824.9278 E,
> 14180802.0043 N (through PostGIS),
> when it looks like it should be (via Google Earth) 553824.9278m E,
> 4180802.0043m N
> Am I using the wrong SRID, or is this some known bug? Is there any way I can
> rectify this and get the correct UTM value straight from PostGIS?
> Any insights would be appreciated,
> thanks,
> Oliver
> postgis-users mailing list
