[postgis-users] bounding box incorrect on circularstring
    Ken Southerland
    southerland at samsix.com
    Tue Sep 30 15:25:53 PDT 2008
I am using Postgres 8.2.4 on Windows and am having an issue with the
Circular Strings in the Postgis extension.
Why is the bounding box of circularstrings incorrectly calculated.  Here
I have a circular string that represents a nearly closed circle...
db=# SELECT astext( geom ) FROM geom_table WHERE id = 0;
  CIRCULARSTRING(220268.439465645 150415.359530563,220227.333322076
150505.561285
879,220227.353105332 150406.434743975)
... but it's extent is a rectangle that only covers the two endpoints
and ignores the middle point and the arc segments in-between...
db=# SELECT astext( extent( geom ) ) FROM geom_table WHERE id = 0;
  POLYGON((220227.34375 150406.421875,220227.34375
150415.375,220268.453125 15041
5.375,220268.453125 150406.421875,220227.34375 150406.421875))
... is this a known issue that is being addressed?
Ken
------s----a----m----s----i----x------
Ken Southerland
Senior Consultant
Sam Six, Inc.
503-358-6542
http://www.samsix.com
