[postgis-users] Finding the buffer of two points
Supunmali Ahangama supunmali7 at gmail.com
Tue Aug 11 03:48:51 PDT 2009
I have two points A and B located in a large region. I need to find the
optimal path between those 2 points. Without considering the whole area (all
the edges), can I consider only a segment that will be required to find the
optimal path. As all the edges (far away roads in other cities) will not be
required to find the optimal path between two points in a city. If all are
considered it will be a waste.
What is the possible function to use and how to solve my issue?
Hope to hear a reply soon. Thanks
View this message in context: http://www.nabble.com/Finding-the-buffer-of-two-points-tp24915312p24915312.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
