[postgis-users] 1.3 to 1.4 upgrade
Paragon Corporation lr at pcorp.us
Thu Aug 20 14:25:31 PDT 2009
Those errors look fine to me.  Those things don't exist in PostGIS 1.4 so
they simply won't be loaded.
Are you using the perl upgrade script.  Haven't tried that so not absolutely
sure.  We usually just restore our old 1.3 ontop of a new mint PostGIS 1.4
and that works pretty well for us, but then again we were doing both
migrations at the same time.
Which platform are you on by the way?
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Matt
Foster
Sent: Thursday, August 20, 2009 12:06 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] 1.3 to 1.4 upgrade
Hello,
I'm moving some Postgis databases to a new physical server.  I decided to
use this opportunity to move from Postgis 1.3 to 1.4.  I'm also going from
Postgres 8.2 to 8.3 (I'm not brave enough to go to the brand new PG 8.4!).
I concluded that the right thing to do was to use the "Hard Upgrade"
method to make this move.  When I ran the upgrade Perl script to restore the
dump on to the new server, I got the following error messages...
ERROR:  language "plpgsql" already exists
ERROR:  function st_histogram2d_in(cstring) does not exist
ERROR:  could not access file "$libdir/liblwgeom": No such file or directory
ERROR:  function public.asukml(geometry, integer, integer) does not exist
ERROR:  function public.asukml(geometry, integer) does not exist
ERROR:  function public.asukml(geometry) does not exist
ERROR:  function public.st_asukml(geometry, integer, integer) does not exist
ERROR:  function public.st_asukml(geometry, integer) does not exist
ERROR:  function public.st_asukml(geometry) does not exist
ERROR:  function public.st_text(boolean) does not exist
ERROR:  function public.text(boolean) does not exist
Following the documentation, I grep'd for ^KEEPING in the log file I
created, and found these entries...
KEEPING TYPE [histogram2d]
KEEPING FUNCTION: [askml(geometry, integer, integer)] KEEPING FUNCTION:
[asukml(geometry, integer, integer)] KEEPING FUNCTION: [asukml(geometry,
integer)] KEEPING FUNCTION: [asukml(geometry)] KEEPING FUNCTION:
[st_askml(geometry, integer, integer)] KEEPING FUNCTION:
[st_asukml(geometry, integer, integer)] KEEPING FUNCTION:
[st_asukml(geometry, integer)] KEEPING FUNCTION: [st_asukml(geometry)]
KEEPING FUNCTION: [st_text(bool)] KEEPING FUNCTION: [text(bool)] KEEPING
FUNCTION: [update_geometry_stats()] KEEPING FUNCTION:
[update_geometry_stats(character varying, character varying)] KEEPING
AGGREGATE [geomunion(geometry)]
Are these messages normal or are they indicating a problem?  Some searching
of the mailing list archive led me to believe that they are normal, but I
would like to be sure before I proceed with the other databases.
Matt
Do not go where the path may lead; go instead where there is no path and
leave a trail.
-- Ralph Waldo Emerson
