[postgis-users] merging linestrings between roadcrossings
Daniel Grum daniel.grum at unibw.de
Tue Dec 1 06:21:59 PST 2009
Stephen Woodbridge schrieb:
> Nicklas Avén wrote:
>> Hallo
>> I have a quite big dataset (approx 1.2 mill rows) with roads. What I
>> would like to to is merging all linestrings between crossings so I
>> get one linestring between two crossings or between a crossing and
>> the end of the road. Now there can be many small parts cut by a
>> bridge or some border. For quality I also have to check so no
>> linestrings are just passing a crossing too, but that is secondary
>> because I don't think that is a problem with this dataset.
>> A while ago I saw a solution on this list which included merging all
>> and dumping, but I think that will be a little heavy in this case.
>> I have been struggling some with recursive queries but I haven't
>> found the way.
>> How to do it?
> Nicklas,
> If I understand what you want correctly, the problem is probably best
> solved, by something like the following:
> 1) assign unique nodes to all segment end points and add start_node_id
> and end_node_id to all your edges. look at pgRouting this have code to
> do this already implemented.
> vertex_ids table
> uid, lat, lon
> 2) add a num_segments column to you unique node table
> 3) update vertex_ids set num_segments=(select count(*) from edges e
> where e.start_node_id=uid or e.end_node_id=uid);
> now num_segments will tell you what you need to know
> num_segments
>  0   - should not happen
>  1   - these are dead end streets
>  2   - these are joinable segments
>  3+  - these are crossing segments
> For the joinable segments create a new joined segment use the segments
>   select * from edges
>    where e.start_node_id=<uid_in_question>
>       or e.end_node_id=<uid_in_question>;
> insert that, and delete the two old segments and fixup your node counts.
> -Steve
> postgis-users mailing list
Hi
I think I have the same problem!
Are there any ideas how I can construct an SQL script that join
streets-->merging linestrings that are not joined?
So a user often build street, that endnodes are not joined with the
other street. So, if the endnode is an a buffer to a digitized
street-->the sql will join this line?!
Is there a way to do this?!
--daniel
