[postgis-users] merging linestrings between roadcrossings
Stephen Woodbridge woodbri at swoodbridge.com
Tue Dec 1 07:06:50 PST 2009
If you use the code from pgRouting to create the unique vertex ids you
can assign a tolerance to use when matching nodes. then I would write a
stored procedure to apply the test and rules that are appropriate to
your data model.
I don't have my postgis manual handy but there is a function the will
allow you to merge two segments IIRC. If not it is pretty easy to
extract the points of the two segments and create a new one combining
the two sets.
-Steve
Daniel Grum wrote:
> Stephen Woodbridge schrieb:
>> Nicklas Avén wrote:
>>> Hallo
>>> I have a quite big dataset (approx 1.2 mill rows) with roads. What I
>>> would like to to is merging all linestrings between crossings so I
>>> get one linestring between two crossings or between a crossing and
>>> the end of the road. Now there can be many small parts cut by a
>>> bridge or some border. For quality I also have to check so no
>>> linestrings are just passing a crossing too, but that is secondary
>>> because I don't think that is a problem with this dataset.
>>> A while ago I saw a solution on this list which included merging all
>>> and dumping, but I think that will be a little heavy in this case.
>>> I have been struggling some with recursive queries but I haven't
>>> found the way.
>>> How to do it?
>> Nicklas,
>> If I understand what you want correctly, the problem is probably best
>> solved, by something like the following:
>> 1) assign unique nodes to all segment end points and add start_node_id
>> and end_node_id to all your edges. look at pgRouting this have code to
>> do this already implemented.
>> vertex_ids table
>> uid, lat, lon
>> 2) add a num_segments column to you unique node table
>> 3) update vertex_ids set num_segments=(select count(*) from edges e
>> where e.start_node_id=uid or e.end_node_id=uid);
>> now num_segments will tell you what you need to know
>> num_segments
>>  0   - should not happen
>>  1   - these are dead end streets
>>  2   - these are joinable segments
>>  3+  - these are crossing segments
>> For the joinable segments create a new joined segment use the segments
>>   select * from edges
>>    where e.start_node_id=<uid_in_question>
>>       or e.end_node_id=<uid_in_question>;
>> insert that, and delete the two old segments and fixup your node counts.
>> -Steve
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Hi
> I think I have the same problem!
> Are there any ideas how I can construct an SQL script that join
> streets-->merging linestrings that are not joined?
> So a user often build street, that endnodes are not joined with the
> other street. So, if the endnode is an a buffer to a digitized
> street-->the sql will join this line?!
> Is there a way to do this?!
> --daniel
