[postgis-users] CLEAN command (was:Cleaning non valid multipolygon)
Stefan Keller sfkeller at gmail.com
Sat Feb 7 15:42:42 PST 2009
Recently there was an interesting thread about "Cleaning non valid
multipolygon". The goal there was to eliminate small polygons. This is
similar to ArcGIS' ELIMINATE command, see
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?id=1398&pid=1394&topicname=Eliminate_(Coverage
Now, there is another command I remember from ArcGIS, called CLEAN (see
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Clean%20(Coverage)).
Among other's, it (1) deletes dangling lines that are shorter than a
specified dangle length, and (2) merges coordinates within a certain
tolerance of each other.
In case, someone has already resolved this using PostGIS, I'd be interested.
-S.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090208/7ed9d49c/attachment.html>
