[postgis-users] CLEAN command (was:Cleaning non valid multipolygon)
herval Fernandes Lopes hervallopes at gmail.com
Mon Feb 9 05:07:02 PST 2009
Test.
Em Dom, 2009-02-08 às 00:42 +0100, Stefan Keller escreveu:
> Hi,
> Recently there was an interesting thread about "Cleaning non valid
> multipolygon". The goal there was to eliminate small polygons. This is
> similar to ArcGIS' ELIMINATE command, see
> http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?id=1398&pid=1394&topicname=Eliminate_(Coverage).
> Now, there is another command I remember from ArcGIS, called CLEAN
> (see
> http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Clean%
> 20(Coverage)).
> Among other's, it (1) deletes dangling lines that are shorter than a
> specified dangle length, and (2) merges coordinates within a certain
> tolerance of each other.
> In case, someone has already resolved this using PostGIS, I'd be
> interested.
> -S.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090209/c891241b/attachment.html>
