[postgis-users] Error using PostGIS and GEOM
张新波(Sinboy Zhang) iamsinboy at gmail.com
Wed Feb 25 00:44:48 PST 2009
I got the same problem.
OS:CentOS 5.2
PostgreSQL:8.2.6
Geos:3.0.0
proj:4.6.0
postgis:1.3.2
A few months ago,i installed them successully on Fedora 7,now a error
boked when i installed on CentOS:
ERROR:  could not load library "/usr/local/postgis/lib/liblwgeom.so":
libgeos_c.so.1:
cannot open shared object file: No such file or directory
But the file liblwgeom.so was existed surely in /usr/local/postgis/lib, i
added /usr/local/postgis/lib to /etc/ld.conf.d/local.conf and execute
ldconfig ,final restart postgresql ,but the error still exist.
2009/2/25 Eduin Yezid Carrillo Vega <yecarrillo at gmail.com>
> Add this line to /etc/ld.so.conf.d/local.conf    :
> /usr/lib64/pgsql/
> And then run:
> ldconfig
> Eduin Yesid Carrillo Vega
> Ingeniero Civil, Esp. Sistemas de Información Geográfica
> Centro de Investigación y Desarrollo en Información Geográfica
> Instituto Geográfico Agustín Codazzi - IGAC
> Cr 30 48-51
> Tel +57 1 3694000  ext 4603
> Bogotá D.C., Colombia
> On Tue, Feb 24, 2009 at 12:39 PM, Giri <giriprakash at gmail.com> wrote:
> > HI,
> > I  recently installed the PostGIS to use it with Geoserver, the project
> that
> > uses the PostGIS needs the GEOM extension. So I installed the GEOM and
> > rebuilt the PostGIS, now I am getting the following error:
> > the PostGIS is running in Linux.
> > any help will be appreciated!.
> > The following exception was thrown:
> > class java.io.IOException: An SQL exception occurred: ERROR: could not
> load
> > library "/usr/lib64/pgsql/liblwgeom.so": libgeos_c.so.1: cannot open
> shared
> > Details:
> > java.io.IOException: An SQL exception occurred: ERROR: could not load
> shared
> >       at
> org.geotools.data.postgis.PostgisDataStore.getGeometryAttribute(PostgisDataStore.java:1124)
> >       at
> org.geotools.data.postgis.PostgisDataStore.buildAttributeType(PostgisDataStore.java:994)
> > Thanks!
> > Giri
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090225/c85cbdfd/attachment.html>
