[postgis-users] Error using PostGIS and GEOM
张新波(Sinboy Zhang) iamsinboy at gmail.com
Wed Feb 25 01:45:51 PST 2009
I found the cause of the problem,because of  the environment variable.
I did want to create a Linux service, start-up,so,i made a pgsqld file in
"root" user.The start cmd is :
cd /home/postgres
su postgres -c "postmaster -i -D /usr/gftech/pgdata &"
I missed the "-"  after "su",the right cmd should be *su - postgres
-c*"postmaster -i -D /usr/gftech/pgdata &"
2009/2/25 张新波(Sinboy Zhang) <iamsinboy at gmail.com>
> I got the same problem.
> OS:CentOS 5.2
> PostgreSQL:8.2.6
> Geos:3.0.0
> proj:4.6.0
> postgis:1.3.2
> A few months ago,i installed them successully on Fedora 7,now a error
> boked when i installed on CentOS:
> ERROR:  could not load library "/usr/local/postgis/lib/liblwgeom.so":
> libgeos_c.so.1:
> cannot open shared object file: No such file or directory
> But the file liblwgeom.so was existed surely in /usr/local/postgis/lib, i
> added /usr/local/postgis/lib to /etc/ld.conf.d/local.conf and execute
> ldconfig ,final restart postgresql ,but the error still exist.
> 2009/2/25 Eduin Yezid Carrillo Vega <yecarrillo at gmail.com>
> Add this line to /etc/ld.so.conf.d/local.conf    :
>> /usr/lib64/pgsql/
>> And then run:
>> ldconfig
>> Eduin Yesid Carrillo Vega
>> Ingeniero Civil, Esp. Sistemas de Información Geográfica
>> Centro de Investigación y Desarrollo en Información Geográfica
>> Instituto Geográfico Agustín Codazzi - IGAC
>> Cr 30 48-51
>> Tel +57 1 3694000  ext 4603
>> Bogotá D.C., Colombia
>> On Tue, Feb 24, 2009 at 12:39 PM, Giri <giriprakash at gmail.com> wrote:
>> > HI,
>> > I  recently installed the PostGIS to use it with Geoserver, the project
>> that
>> > uses the PostGIS needs the GEOM extension. So I installed the GEOM and
>> > rebuilt the PostGIS, now I am getting the following error:
>> > the PostGIS is running in Linux.
>> > any help will be appreciated!.
>> > The following exception was thrown:
>> > class java.io.IOException: An SQL exception occurred: ERROR: could not
>> load
>> > library "/usr/lib64/pgsql/liblwgeom.so": libgeos_c.so.1: cannot open
>> shared
>> > Details:
>> > java.io.IOException: An SQL exception occurred: ERROR: could not load
>> shared
>> >       at
>> org.geotools.data.postgis.PostgisDataStore.getGeometryAttribute(PostgisDataStore.java:1124)
>> >       at
>> org.geotools.data.postgis.PostgisDataStore.buildAttributeType(PostgisDataStore.java:994)
>> > Thanks!
>> > Giri
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090225/f64bbc2b/attachment.html>
