[postgis-users] Pgrouting directions
a7mad bdair2002 at gmail.com
Mon Jan 5 12:07:21 PST 2009
Stephen Woodbridge wrote:
> In the example I used below, the road segment would have had 4 points,
> but regardless of the number of points, you would use:
> pnt[1], pnt[2] for the calculations at the start of the segment.
> pnt[numpoints-1], pnt[numpoints] for the calculations at the end of
> the segment.
> So in postgis you could use:
> st_x(st_pointn(the_geom, 1))  or st_x(st_startpoint(the_geom))
> st_y(st_pointn(the_geom, 1))  or st_y(st_startpoint(the_geom))
> st_x(st_pointn(the_geom, 2))
> st_y(st_pointn(the_geom, 2))
> st_x(st_pointn(the_geom, st_numpoints(the_geom)-1))
> st_y(st_pointn(the_geom, st_numpoints(the_geom)-1))
> st_x(st_pointn(the_geom, st_numpoints(the_geom)))  or
> st_x(st_endpoint(the_geom))
> st_y(st_pointn(the_geom, st_numpoints(the_geom)))  or
> st_y(st_endpoint(the_geom))
> If you need to compute the bearing or Azimuth of the segment ends look
> at this:
> http://postgis.refractions.net/pipermail/postgis-users/2007-November/017768.html
> http://postgis.refractions.net/documentation/manual-svn/ST_Azimuth.html
> -Steve
> Ahmad Bdair wrote:
>> Thanx Steve, your information were helpful, but when I think of it it
>> confuses me a lot, lets first start with my fields in DB.
>> Columns are:
>>   gid serial NOT NULL,
>>   rod_name_a character varying(50),
>>   label character varying(50),
>>   rod_length integer,
>>   rod_no integer,
>>   rod_type character varying(1),
>>   rod_class character varying(1),
>>   rod_code character varying(10),
>>   shape_leng numeric,
>>   the_geom geometry,
>>   source integer,
>>   target integer,
>>   length double precision,
>>   x1 double precision,
>>   y1 double precision,
>>   x2 double precision,
>>   y2 double precision,
>>   to_cost double precision,
>>   "rule" text,
>>   cost_factor integer,
>>   main_cost double precision,
>>   reverse_cost double precision,
>>   roadclass text DEFAULT 'OTHER'::text,
>>   cost_reverse_factor integer DEFAULT 5,
>> Now, I am confused, because I cannot calculate the heading in the
>> first place, If I have
>> B+---\
>> x2,y2
>> x1,y1
>> A+---/
>> Now I can calculate the heading simply by comparing x1 and y1 to x2
>> to y2 and which is larger (based on lonlat) so I can judge it, but
>> some times I am having this:
>> B+---\
>> x1,y1
>> x2,y2
>> A+---/
>> Now it is misleading, maybe thats why you told me not to use start
>> and end point, but wait, what else to use ? According to my DB I
>> cannot think of any other way to calculate headings and angles.
>> Regards
>> On Wed, Dec 31, 2008 at 7:45 AM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>     Ahmad Bdair wrote:
>>         Yes, that is something very similar to what I need to do, I
>>         already wrote a php code to check angels and slopes, but it was
>>         not accurate, it was more life "if else" code, I check the
>>         longlat for current segment
>>     When you check the angles do not use the end points because they are
>>     mis-leading.
>>     B+---\
>>     A+---/
>>     If you have a segment from A to B like the above and you calculate
>>     the heading or angles based on the vector AB then it will point
>>     north and is should be pointing west at the end of the vector or
>>     east at the start of the vector.
>>     You also need to look at weather or not you need to flip segments
>>     because you route might traverse them from start to end OR from end
>>     to start.
>>     When I compute angles I grid the angles into 8 pie pieces of 45
>>     degrees each.
>>     continue straight
>>     turn slight right/left
>>     turn right/left
>>     turn sharp right/left
>>     make a u-turn
>>         with longlat for the previous one, I guess you didn't use the
>>         database for direction calculation(except for routing) am I
>>         right? Isn't steps 3 and 4 depends on your angel calculations?
>>     I have done this in C in a prototype router I wrote years ago. I
>>     have implemented it in PHP and in perl in various incarnations in
>>     the past. The demo page has it written in pgpsql, but it is based on
>>     my own heavily modified versions of the pgRouting stored procedures.
>>     Hope the above helps with your problems. I find it easiest to work
>>     out the math problems of computing the angles and headings first and
>>     make sure they are correct. Then move on to the other issues. If
>>     your math is wrong computing the headings and angles it will cloud
>>     all the other results.
>>     Best regards,
>>      -Steve
>>         I have the roads with two different languages, a road map like
>>         anyother road map I guess.
>>         On Tue, Dec 30, 2008 at 3:17 AM, Stephen Woodbridge
>>         <mailto:woodbri at swoodbridge.com>>> wrote:
>>            bdair2002 wrote:
>>                Hello,
>>                I am developing an application using Pgrouting with
>> Postgis
>>                data, everything
>>                is fine, but now I am looking  to do something like
>> Google
>>                directions guide,
>>                where it tells you turn left or right, I am wondering
>> if this
>>                feature is a
>>                built-in feature in Pgrouting or Postgis.
>>                Regards
>>            No this is not a feature that is part of either.
>>            I have implemented a directions explicator, but it is
>> somewhat
>>            specific to the data that you have, as you need to know what
>>            column(s) contain the road names, if you have signage
>> information
>>            then you need to know how to link to that. If you want to be
>>         able to
>>            explicate in multiple languages, then you probably need to
>>         consider
>>            supporting multiple languages each in a separate table the
>>         you can
>>            select from when you generate the languages.
>>            The algorithm is pretty straight forward as the you currently
>>         get a
>>            list of segments that make up the route. Then you need to:
>>            analyze each segment and
>>            1) check to see if you want to join it with the previous
>> segment
>>            because the road name matches
>>            2) check the angle that it makes with the last segment to
>>         determine
>>            right, left, straightness of turn
>>            3) compute the compass heading for the segment
>>            4) determine if you have signage
>>            5) based on these, determine if you are read to explicate and
>>         which
>>            predefined instruction you need to explicate an instruction
>>            6) loop through all segments
>>            For a demo of this you can try:
>>            http://imaptools.com/leaddog/routing/dd.html
>>            Zoom into a city in one of the yellow areas, set a start
>> and end
>>            point and click [calculate route] button. The driving
>> directions
>>            should show below the button if it was successful, be
>>         patience the
>>            routing is running on a 333MHz box.
>>            -Steve
>>            _______________________________________________
>>            postgis-users mailing list
>>            postgis-users at postgis.refractions.net
>>         <mailto:postgis-users at postgis.refractions.net>
>>         <mailto:postgis-users at postgis.refractions.net>>
>>            http://postgis.refractions.net/mailman/listinfo/postgis-users
Now that makes a lot of sense, thank you very much, by the way, offtopic
subject, I tried to enable routing to work on IE without any success, I
checked your site but it is not working also (IE 7), is there any work
around for IE (I know it sucks to develop on IE).
