[postgis-users] Postgis witjh postgresql 8.1.11
Andrew Sheedy drew at olvec.net
Fri Jun 12 17:18:21 PDT 2009
Ah Gentoo I love thee.
Check this blog entry Brian:
http://hasno.info/2008/7/31/upgrading-to-postgresql-8-3-on-gentoo
<http://hasno.info/2008/7/31/upgrading-to-postgresql-8-3-on-gentoo>The gist
of it being:
..largely due to the overall postgresql upgrade philosophy, which involves
> dumping (backing up) all your dbs and the restoring them after the upgrade.
> Since that isn't a seamless process, I'm sure they want an upgrade to be a
> conscious decision. That being said, the current upgrade path involves
> switching from the dev-db/postgresql package to the dev-db/postgresql-base
> /dev-db/postgresql-serverpackages.
HTH
Drew
On Sat, Jun 13, 2009 at 3:29 AM, Brian Modra <brian at zwartberg.com> wrote:
> Hi
> does anyone know of any problems with postgis in postgresql 8.1.11 ?
> I'm using postgis 1.3.1 in postgresql 8.1.11
> uname says:
> Linux lead 2.6.24-gentoo-r4 #1 SMP Sat Apr 5 18:42:58 SAST 2008 i686
> Intel(R) Xeon(TM) CPU 3.40GHz GenuineIntel GNU/Linux
> The reason I ask is that Gentoo's package management system (portage)
> wanted to downgrade postgres to 8.0.15...
> I assume this is because postgis was tested by the gentoo maintainers
> on postgres 8.0.15 only, but I'm a bit concerned that there may be
> some problem they spotted in the 8.1 database.
> Can anyone confirm that postgis 1.3.1 is actually totally stable in
> postgresql 8.1.11  ?
> Thanks
> Brian
> Brian Modra   Land line: +27 23 5411 462
> Mobile: +27 79 69 77 082
> 5 Jan Louw Str, Prince Albert, 6930
> Postal: P.O. Box 2, Prince Albert 6930
> South Africa
> http://www.zwartberg.com/
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090613/94825e54/attachment.html>
