[postgis-users] Postgis witjh postgresql 8.1.11
Gérald Fenoy djayweb at djayux.net
Sat Jun 13 02:32:37 PDT 2009
Hi Brian,
I also answer (quite faster than in my previous mail) on this mailling
list.
You could use any PostgreSQL version you want. For this, you just have
to tell portage that you want ot use an *unstable* postgresql version
as spécified also in the blog entry provided by Drew.
Regards,
Le 13 juin 09 à 02:18, Andrew Sheedy a écrit :
> Ah Gentoo I love thee.
> Check this blog entry Brian: http://hasno.info/2008/7/31/upgrading-to-postgresql-8-3-on-gentoo
> The gist of it being:
> ..largely due to the overall postgresql upgrade philosophy, which
> involves dumping (backing up) all your dbs and the restoring them
> after the upgrade. Since that isn't a seamless process, I'm sure
> they want an upgrade to be a conscious decision. That being said,
> the current upgrade path involves switching from the dev-db/
> postgresql package to the dev-db/postgresql-base/dev-db/postgresql-
> serverpackages.
> HTH
> Drew
> On Sat, Jun 13, 2009 at 3:29 AM, Brian Modra <brian at zwartberg.com>
> wrote:
> Hi
> does anyone know of any problems with postgis in postgresql 8.1.11 ?
> I'm using postgis 1.3.1 in postgresql 8.1.11
> uname says:
> Linux lead 2.6.24-gentoo-r4 #1 SMP Sat Apr 5 18:42:58 SAST 2008 i686
> Intel(R) Xeon(TM) CPU 3.40GHz GenuineIntel GNU/Linux
> The reason I ask is that Gentoo's package management system (portage)
> wanted to downgrade postgres to 8.0.15...
> I assume this is because postgis was tested by the gentoo maintainers
> on postgres 8.0.15 only, but I'm a bit concerned that there may be
> some problem they spotted in the 8.1 database.
> Can anyone confirm that postgis 1.3.1 is actually totally stable in
> postgresql 8.1.11  ?
> Thanks
> Brian
> Brian Modra   Land line: +27 23 5411 462
> Mobile: +27 79 69 77 082
> 5 Jan Louw Str, Prince Albert, 6930
> Postal: P.O. Box 2, Prince Albert 6930
> South Africa
> http://www.zwartberg.com/
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090613/fb2194f7/attachment.html>
Desc: Ceci est une signature ?lectronique PGP
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090613/fb2194f7/attachment.pgp>
