[postgis-users] Re: errors loading postgis.sql
strk strk at keybit.net
Wed May 13 01:07:31 PDT 2009
On Wed, May 13, 2009 at 12:52:41PM +0530, rahul.pachaghare at tcs.com wrote:
> Hi..
> Thank you for your reply....
> the first few lines are:
>  psql -d newpsqldb -f lwpostgis.sql -U postgres | less
> psql:lwpostgis.sql:44: NOTICE:  type "histogram2d" is not yet defined
> DETAIL:  Creating a shell type definition.
> psql:lwpostgis.sql:44: ERROR:  could not load library
> "/usr/local/pgsql/lib/liblwgeom.so": libgeos_c.so.1: cannot open shared
> object file: No such file or directory
Did you run 'ldconfig' as root after installing GEOS ?
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
