[postgis-users] 3dm point table def
Paragon Corporation lr at pcorp.us
Sun Oct 18 00:40:34 PDT 2009
Yes the ST_AsText() only gives the 2D representation even for 3D geometries.
Its based on an older OGC standard before 3D was introduced into OGC/MM
specs.
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Jun
Koike
Sent: Sunday, October 18, 2009 12:08 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] 3dm point table def
I've tried your example and got 3-dimension geometry by this query...
SELECT ST_AsEWKT(roads_geom) FROM road;
(Windows+PostgreSQL8.3+PostGIS(I forgot my version...sorry))
I think geometry itself is inserted well but somehow ST_AsText() gives only
2-dimension geometry...as your result, is this because of WKT specification
on PostGIS???
Regards,
2009/10/18 Masanao Yajima <yajiyajijp at yahoo.co.jp>:
> Hi list
> I have question regarding making 3DM point column in PostGIS.
> When I try to insert POINTM(x,y,m),
> if the dimension of the column is 3 it drops the M dimension, and when
> I make the dimension 4 it asks for the z dimension.
> How should I make the geometry column to have only x,y,m so I can
> insert POINTM?
> Here is example of the query
> CREATE TABLE road(
>   road_id INTEGER,
>   road_name VARCHAR
> SELECT AddGeometryColumn( 'road', 'roads_geom', -1, 'GEOMETRY',3 );
> insert into temptest (road_id, road_name, roads_geom) values
> (21,'test',
> ST_GeomFromEWKT('POINTM(191232 243118 1111)'))
> select st_astext(roads_geom) from temptest
> I appreciate your help!
> Masanao Yajima
> postgis-users mailing list
Jun KOIKE
jun.july.25 at gmail.com
