[postgis-users] postgis.sql
Jorge Arévalo jorge.arevalo at gmail.com
Thu Sep 10 02:10:25 PDT 2009
There should be more info about errors in the output. Could you
copy&paste them here? If not, it's really difficult to help you
On Thu, Sep 10, 2009 at 11:07 AM, Mark Vantzelfde
<netmasters.ma at gmail.com> wrote:
> After installing/configuring/making geos, proj4 and postgis from sources on
> a new Linux system along with a fresh install of postgresql, I cannot run
> the postgis.sql file. I am getting " ERROR:  current transaction is aborted,
> commands ignored until end of transaction block" errors.
> When I ran configure for the postgis build, I had to specify the paths to
> geos, proj.4 and postgresql so required libs might not be in the expect
> locations. I tried setting LD_LIBRARY_PATH but I am not certain what libs
> are needed or where to find them on my system.
> Ideas on how to resolve?
> Thanks
> Mark Vantzelfde
> postgis-users mailing list
