[postgis-users] linestring clipping problem
James G Wilkinson jgw at alpinegeophysics.com
Wed Sep 30 11:23:34 PDT 2009
Folks,
I am having a problem determining the best way to clip out and disgrad a set
of linestrings.  Here is my setup:
itn=# select postgis_full_version();
 POSTGIS="1.3.2" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
USE_STATS (procs from 1.1.2 need upgrade)
(1 row)
itn=# select version();
                                                 version
 PostgreSQL 8.1.3 on x86_64-unknown-linux-gnu, compiled by GCC gcc (GCC)
4.0.0 20050519 (Red Hat 4.0.0-8)
(1 row)
My linestring network has the following attributes (and a picture for
visualization):
itn=# \d itn.scaglinks
                                                  Table "itn.links"
         Column         |       Type       |
Modifiers
 record_id_alternate    | integer          | not null default
nextval('itn.scaglinks_record_id_alternate_seq3'::regclass)
 a_node                 | integer          |
 b_node                 | integer          |
 dist                   | integer          |
 taz_id                 | integer          |
 .<clip>
 .<clip>
 the_geom               | geometry         |
Indexes:
    "idx_scaglinks_00" btree (a_node)
    "idx_scaglinks_01" btree (b_node)
    "idx_scaglinks_02" btree (a_node, b_node)
    "idx_scaglinks_03" btree (link_id)
    "pkgis_scaglinks" gist (the_geom)
Check constraints:
    "enforce_dims_the_geom" CHECK (ndims(the_geom) = 2)
    "enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
'MULTILINESTRING'::text OR the_geom IS NULL)
    "enforce_srid_the_geom" CHECK (srid(the_geom) = 26911)
My clipping polygon has the following attributes (and a picture for
visualization):
itn=# \d itn.itn_clip_polygon_1
 Table "itn.itn_clip_polygon_1"
  Column  |   Type   | Modifiers
 cyid     | integer  |
Indexes:
    "pkgis_itn_clip_polygon_1" gist (the_geom)
When I run the following command to clip the scaglinks linestrings, the
results are what I would expect (again, a picture for visualization):
itn=# create table clipped as select intersection(a.the_geom,b.the_geom) as
new_geom, length(a.the_geom) as original_link_length, a.* from scaglinks a,
itn_clip_polygon_1 b where intersects(a.the_geom,b.the_geom);
SELECT
itn=# create index pkgis_clipped on clipped using gist(new_geom);
CREATE INDEX
itn=# \d itn.clipped
                  Table "itn.clipped"
 new_geom               | geometry         |
 original_link_length   | double precision |
 a_node                 | integer          |
 b_node                 | integer          |
 dist                   | integer          |
 taz_id                 | integer          |
 .<clip>
 .<clip>
Indexes:
    "pkgis_clipped" gist (new_geom)
What I am really after are the links that fall outside the clipping
polygon.  So I attempted the following query:
itn=# create table clipped2 as SELECT a.*, difference(a.the_geom,b.new_geom)
as new_geom from scaglinks a, clipped b;
******** after 12 hours, the query throws the following error ********
ERROR: could not extend relation 1663/164540/180960: No space left on device
HINT: Check free disk space
The scaglinks network consists of 108,000 links and the clipped network
consists of 6,200 links.  I have approximately 1.5 TB of free disk so I
do not believe that disk space should be a problem.
Again, what I had hoped is that the query to create clipped2 would return
a table that results in the following graphic:
Can you offer any help in the query that will result in a table that
looks something like the last graphic?
Best Regards,
Jim
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090930/5f4e7c32/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090930/5f4e7c32/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090930/5f4e7c32/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090930/5f4e7c32/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090930/5f4e7c32/attachment-0003.png>
