[postgis-users] PostGIS 1.5.1 causing postmaster crash on index creation
Nicholas Bower nick at petangent.net
Thu Apr 15 05:51:20 PDT 2010
Just upgraded to PostGIS 1.5.1 on a windows XP machine (from 1.3.4) and when
creating an index on a geography column using this single statement;
CREATE INDEX t_swath_metadata_swath_bounding_key ON wastac.t_swath_metadata
USING gist (swath_bounding);
I get a client error
DEBUG:  StartTransactionCommandDEBUG:  StartTransactionDEBUG:  name:
unnamed; blockState:       DEFAULT; state: INPROGR, xid/subid/cid: 0/1/0,
nestlvl: 1, children:DEBUG:  ProcessUtilityDEBUG:  mapped win32 error code 2
to 2
********** Error **********
and find the entire server / postmaster has crashed and no longer running.
 Log below;
2010-04-15 22:35:12 EST LOG:  database system was interrupted; last known up
at 2010-04-15 22:32:33 EST
2010-04-15 22:35:12 EST LOG:  database system was not properly shut down;
automatic recovery in progress
2010-04-15 22:35:13 EST LOG:  redo starts at C/F5D9EAB0
2010-04-15 22:35:13 EST LOG:  loaded library
"$libdir/plugins/plugin_debugger.dll"
2010-04-15 22:35:13 EST FATAL:  the database system is starting up
2010-04-15 22:35:13 EST LOG:  unexpected pageaddr C/EEFDE000 in log file 12,
segment 246, offset 16637952
2010-04-15 22:35:13 EST LOG:  redo done at C/F6FDCC90
2010-04-15 22:35:13 EST LOG:  last completed transaction was at log time
2010-04-15 22:33:37.687+10
2010-04-15 22:35:14 EST LOG:  loaded library
2010-04-15 22:35:14 EST FATAL:  the database system is starting up
2010-04-15 22:35:14 EST LOG:  database system is ready to accept connections
2010-04-15 22:35:15 EST LOG:  loaded library
2010-04-15 22:36:22 EST LOG:  loaded library
2010-04-15 22:36:26 EST LOG:  loaded library
2010-04-15 22:36:27 EST LOG:  loaded library
*2010-04-15 22:36:35 EST LOG:  server process (PID 14600) was terminated by
exception 0xC0000005*
*2010-04-15 22:36:35 EST HINT:  See C include file "ntstatus.h" for a
description of the hexadecimal value.*
2010-04-15 22:36:35 EST LOG:  terminating any other active server processes
2010-04-15 22:36:35 EST WARNING:  terminating connection because of crash of
another server process
2010-04-15 22:36:35 EST DETAIL:  The postmaster has commanded this server
process to roll back the current transaction and exit, because another
server process exited abnormally and possibly corrupted shared memory.
2010-04-15 22:36:35 EST HINT:  In a moment you should be able to reconnect
to the database and repeat your command.
2010-04-15 22:36:35 EST LOG:  all server processes terminated;
reinitializing
2010-04-15 22:36:36 EST FATAL:  pre-existing shared memory block is still in
use
2010-04-15 22:36:36 EST HINT:  Check if there are any old server processes
still running, and terminate them.
I have been using this Postgresql instance (8.3) with PostGIS 1.3.4 for a
long time previously to do similar operations on geometries and never
encountered a crash like this.
I must admit there is not much to go on with that log above - raising to
debug shows below:
2010-04-15 22:48:57 EST DEBUG:  StartTransactionCommand
2010-04-15 22:48:57 EST DEBUG:  name: unnamed; blockState:       DEFAULT;
state: INPROGR, xid/subid/cid: 0/1/0, nestlvl: 1, children:
2010-04-15 22:48:57 EST DEBUG:  ProcessUtility
2010-04-15 22:48:57 EST DEBUG:  mapped win32 error code 2 to 2
2010-04-15 22:48:59 EST DEBUG:  reaping dead processes
2010-04-15 22:48:59 EST DEBUG:  server process (PID 15736) was terminated by
2010-04-15 22:48:59 EST HINT:  See C include file "ntstatus.h" for a
2010-04-15 22:48:59 EST LOG:  server process (PID 15736) was terminated by
2010-04-15 22:48:59 EST LOG:  terminating any other active server processes
2010-04-15 22:48:59 EST DEBUG:  sending SIGQUIT to process 13536
2010-04-15 22:48:59 EST DEBUG:  sending SIGQUIT to process 14200
2010-04-15 22:48:59 EST DEBUG:  sending SIGQUIT to process 13948
2010-04-15 22:48:59 EST LOG:  all server processes terminated;
reinitializing
2010-04-15 22:48:59 EST DEBUG:  shmem_exit(0)
2010-04-15 22:48:59 EST DEBUG:  invoking IpcMemoryCreate(size=36741120)
2010-04-15 22:49:00 EST FATAL:  pre-existing shared memory block is still in
use
2010-04-15 22:49:00 EST HINT:  Check if there are any old server processes
2010-04-15 22:49:00 EST DEBUG:  proc_exit(1)
2010-04-15 22:49:00 EST DEBUG:  shmem_exit(1)
2010-04-15 22:49:00 EST DEBUG:  exit(1)
2010-04-15 22:49:00 EST DEBUG:  logger shutting down
2010-04-15 22:49:00 EST DEBUG:  proc_exit(0)
2010-04-15 22:49:00 EST DEBUG:  shmem_exit(0)
2010-04-15 22:49:00 EST DEBUG:  exit(0)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100415/34451e32/attachment.html>
