[postgis-users] PostGIS 1.5.1 causing postmaster crash on index creation
Paul Ramsey pramsey at cleverelephant.ca
Thu Apr 15 07:32:09 PDT 2010
Nicholas,
Could you confirm that the crash is building an index on a *geography*
column, not a *geometry* column? Ie, the problem has not been
introduced to old geometry code, it's something in the new geography
code.
After that I'm going to need the data that causes the error...
Paul
On Thu, Apr 15, 2010 at 5:51 AM, Nicholas Bower <nick at petangent.net> wrote:
> Just upgraded to PostGIS 1.5.1 on a windows XP machine (from 1.3.4) and when
> creating an index on a geography column using this single statement;
> CREATE INDEX t_swath_metadata_swath_bounding_key ON wastac.t_swath_metadata
> USING gist (swath_bounding);
