[postgis-users] PostGIS 1.5.1 causing postmaster crash on index creation
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Apr 15 07:38:23 PDT 2010
Paul Ramsey wrote:
> Nicholas,
> Could you confirm that the crash is building an index on a *geography*
> column, not a *geometry* column? Ie, the problem has not been
> introduced to old geometry code, it's something in the new geography
> code.
> After that I'm going to need the data that causes the error...
> Paul
If it's some kind of memory clobbering bug, then perhaps changing endian
  will make a difference. Has anyone tried this on a large endian
architecture?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
