[postgis-users] searching a valid query to return the borders of a	country
    Frederik Ramm
    frederik at remote.org
    Sun Dec  5 09:26:58 PST 2010
Torsten Mohr wrote:
> i'm searching for an SQL query that returns the borders of a country or
> better, _all_ countries.
The correct SQL query depends on the data structure in your data base.
If your data has been imported from OpenStreetMap then the answer to
your question requires a lot of knowledge about the OpenStreetMap data
model and how osm2pgsql works.
You are on the wrong mailing list. I believe explained this to you already.
To solve your problem, I suggest to import one of the shape files from
http://www.naturalearthdata.com/downloads/10m-cultural-vectors/. The
first file in that list, "Admin 0 - Countries" will give you a nice
polygon for every country in the world.
Bye
Frederik
Frederik Ramm  ##  eMail frederik at remote.org  ##  N49°00'09" E008°23'33"
