[postgis-users] digit problem about sql file.
Hyung Joo Lee procarrie at imrc.kist.re.kr
Thu Feb 4 00:08:46 PST 2010
Thanks for your answer.
The following methods have been temporarily resolved.
Well, basically I want to know why those symptoms appear.
About two issues as if maybe I gotta know better.
More I look forward to your response.
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of ibrahim saricicekㅍ
Sent: Thursday, February 04, 2010 4:47 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] digit problem about sql file.
Hi;
use round function
SELECT round(4.1255545487878546, 4);
result---> 4.1256
Regards...
On Thu, Feb 4, 2010 at 9:40 AM, Hyung Joo Lee <procarrie at imrc.kist.re.kr> wrote:
Hi all.
I have a question about the decimal of shapefile that was created in Arcgis.
The file I have defined the coordinates of the coordinate system like (56.631 55.612)
That file was put in the DB using shp2pgsql( ---# shp2pgsql -a -w -S -I ###.shp table_name > ###.sql).
And then I checked the sql file. But the point coordinates that comes a lot more than 3-digit  like 56.6313000004739 55.6119999999646
I want to come out only 3-digit, so how can I do?
What option should I use?
I'll wait for the users a clear answer.
Best regards and thanks in advance.
Kevin.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
