[postgis-users] Windows installers for PostGIS 1.5.0 and PL/R
Jan Hartmann j.l.h.hartmann at uva.nl
Tue Feb 23 04:53:04 PST 2010
Somewhat off topic, has anyone ever worked with Rattle
(http://rattle.togaware.com/)? It's a visual front end for R, mainly
directed at data mining (http://www.togaware.com/datamining/survivor/) .
It's an interesting way of getting novice users into the complexities of
R. I could imagine something like this would be very useful for a
PostGIS/R enabled database, but it would mean a lot of work to integrate
all the diverse packages. Perhaps people with more experience in making
software interoperable could have a look at it?
Jan
On 23-2-2010 3:04, Paragon Corporation wrote:
> The PostGIS 1.5.0 windows installer is now up on Stack Builder.
> New major change to it is that it is packaged with the shp2pgsql-gui
> graphical shape file loader which allows you to import shapefiles directly
> from PgAdmin III and reads the connection settings of your selected database
> automagically :).
> For PostgreSQL 8.4 users, this should automatically enable itself as a
> plugin in the PgAdmin III packaged with PostgreSQL 8.4 if you select "Yes"
> to the new prompt.
> If you happen to use a windows desktop (and are using PgAdmin 1.10+) , but
> have your PostgreSQL installed on a separate server (Linux or Windows) or
> you are running only PostGIS 1.4 or lower, you can still use the plugin
> By downloading it separately from
> http://www.postgis.org/download/windows/ (PostGIS Shp2PgSQL Graphical
> Loader)
> Or alternatively just copy the postgisgui folder (from bin of a PostgreSQL
> windows install) and overwrite your PgAdmin III plugins.ini with the
> plugins.postgis.ini included in the PostgreSQL/.../PgAdminIII/ folder
> On a slightly unrelated note:  Mike Leahy was gracious enough to package a
> PL/R windows installer for 8.3 and 8.4.  Those who've been waiting for PL/R
> to work again on PostgreSQL windows -- wait no longer.
> For those who have been thinking of a good execuse toe start writing PL/R
> stored functions, give it a try.  Its great and a  great companion for
> PostGIS.
> Those unfortunately are not available on Stack Builder, but you can download
> them from:
> http://www.joeconway.com/plr/
> Thanks,
> Regina and Leo
> postgis-users mailing list
