[postgis-users] installation on windows
Nicholas Bower nick at petangent.net
Sun May 16 05:50:44 PDT 2010
Capture the start of the log and the first statement that fails.  Below is
just repeating that there was an initial failure and it is not executing
more statements within this transaction.  For example I've often found
aborts caused by inadequate permissions, in which case something like -u <db
owner> can be required.
On 16 May 2010 21:26, arnauld ndefo <ndefo2002 at yahoo.fr> wrote:
> Hi everybody,
> i am a new developer who use a mapnik to build my own map. I use Window
> instead of ubuntu.I want to know how to install postgis on windows?
> when i do "psql  -d gis -f "c:\Program Files\PostgreSQL\8.3\share\co
> ntrib\lwpostgis.sql" on my windows command shell i have this list of
> error:
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4858:
> ERROR:  c
> urrent transaction is aborted, commands ignored until end of transaction
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4864:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4870:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4876:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4882:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4888:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4894:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4900:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4906:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4912:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4918:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4923:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4928:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4933:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4938:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4948:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4958:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4968:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4979:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4989:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:4999:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:5009:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:5019:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:5025:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:5031:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:5041:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:5051:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:5061:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:5071:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:5077:
> ERROR:  c
> block
> psql:c:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql:5083:
> ERROR:  c
> block
> I don't know how to result this problem, please help me
> thank you
> Ndefo Kamgne Arnauld
> Cité Ettayour,Immeuble Bolbol 1,Appartement A2,Ariana
> 0021624249357
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100516/12d2ef59/attachment.html>
