[postgis-users] ST_DWithin with radius 0.000001
nguyen liem liemnguyendl at gmail.com
Tue May 25 01:37:06 PDT 2010
Hi Nicklas
Actually the points can be outside the polygon and returning true but it can
be tolerance about 1 meters outside.
I'm using SRID: 4326. I would like to know 0.00001 with the projection 4326
is equal 1 meter or not ?
I used ST_Intersects (geom, geometry); but it's really slow, I don't know
why.
I also used ST_Dwithin (geom, geometry, 0) and the result is empty, i
couldn't found any neighbour.
Cheers
On Tue, May 25, 2010 at 3:22 PM, Nicklas Avén <nicklas.aven at jordogskog.no>wrote:
> Hallo
> What you are doing with ST_Dwithin is to check if your geom and geometry
> have parts closer to (or exactly) 0.00001 mapunits from eachother. If you
> are using a meter based SRID then you are checking if they are within
> 0.00001 meters from eachother. So actually in this case your points can be
> just outside the polygon and returning true. If you want to use st_dwithin
> you should use 0 instead of 0.00001 . But I don't think that is any faster
> than ST_Intersects. The important thing in both cases is to have working
> spatial indexes.
> put an index on geom column in my_neighbour table and analyze the table.
> Create index idx_mn_geom
> on my_neighbour
> using gist(geom);
> analyse my_neighbour;
> Then try:
> SELECT id, geom
> FROM my_neighbour
> WHERE ST_Intersects (geom, geometry);
> I guess that is the best solution.
> Hope that helps
> Nicklas
> 2010-05-25 nguyen liem wrote:
> Hi all
> >At the first time i used ST_Contains but it take a long time, so I used
> ST_Dwithin to improve the performance for the query statement but i don't
> know it is correct or not.
> >I would like to know my points are within in polygon or not:
> >SELECT id, geom
> >FROM my_neighbour
> >WHERE ST_Dwithin (geom, geometry, 0.00001)
> >geometry: is a polygon(input parameter).
> >0.00001: I means the radius of geometry is 1 meters, is it right?
> >Cheers.
> >Liem Nguyen
> >Developer
> >Axon Active Corp.
> >Direct Line      : +84 38 948 4645
> >Fax                  : +84 38 811 3489
> > Mobile Phone  : +84 168 994 8897
> >Skype ID         : liemnguyendl2204
> >Email               : liem.nguyen at axonactive.net / liemnguyendl at gmail.com
> > Web Site          : axonactive.vn
> >Address           : 87 Thang Long Street,Gate 2 Ward 4,
> >                          Tan Binh District, HCM city, Vietnam.
> postgis-users mailing list
Liem Nguyen
Developer
Axon Active Corp.
Web Site          : http://axonactive.vn
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100525/4f7ed837/attachment.html>
