[postgis-users] Installing a fully functional PostGIS 2.0 on Ubuntu Linux GEOS/GDAL issues
Carlos Andrade carlosviansi at gmail.com
Sat Dec 24 22:29:21 PST 2011
Hello,
I have a tutorial for mac, I'm not sure if it is useful for the kind of
problem you are having because I found installers (links provided there on
the tutorial) for mac.
I'm sorry I did not post this earlier, semester vacation only started early
and I'm still unable to understand how to post there on the wiki.
http://wiki.dcc.ufba.br/~CarlosSilva
Tutorial is available on this wiki, just search for the following exactly
words:
*Postgres 9.1 e Postgis 1.5.3*:
If anyone could tell me how to post it, or just post at postgis wiki with
given credits I would be thankful.
Best regards,
Carlos Andrade
http://carlosandrade.co
2011/12/25 THX1138 <ap.joseph at live.com>
> I am new to linux, postgresql and postgis. I have been working on getting
> postgis 2.0 up and running on an ubuntu-maverick-amd64 linux server for
> about a week now. I am going for raster and topology support.
> I used the following to configure:
> sudo ./configure --with-raster --with-topology
> --with-jsondir=/home/zonabili/json-c-0.9
> The configuration file below describes my specs.
> PostGIS is now configured for x86_64-unknown-linux-gnu
> -------------- Compiler Info -------------
>  C compiler:           gcc -g -O2
>  C++ compiler:         g++ -g -O2
> -------------- Dependencies --------------
>  GEOS config:          /usr/local/bin/geos-config
>  GEOS version:         3.3.1
>  GDAL config:          /usr/bin/gdal-config
>  GDAL version:         1.8.0
>  PostgreSQL config:    /usr/bin/pg_config
>  PostgreSQL version:   PostgreSQL 9.1.2
>  PROJ4 version:        47
>  Libxml2 config:       /usr/bin/xml2-config
>  Libxml2 version:      2.7.7
>  JSON-C support:       Yes
>  PostGIS debug level:  0
> -------------- Extensions --------------
>  PostGIS Raster:       0.1.6d
>  PostGIS Topology
> -------- Documentation Generation --------
>  xsltproc:             /usr/bin/xsltproc
>  xsl style sheets:
>  dblatex:              /usr/bin/dblatex
>  convert:              /usr/bin/convert
> I managed to run make and sudo make install with older (and useless for new
> functions) versions of gdal and geos. Thus, my guess is that the problems
> lies with my install of GEOS or GDAL. There is no 3.3.1 downloadable
> package
> for my linux version so I had to build from source and I probably messed
> this up as I am not used to doing it, although I followed the directions
> provided on the website and downloaded the tarfile. I did not deviate from
> the instructions other than cd-ing to the directory to configure make and
> install. I did everything that it explicitly stated that I should do. I
> didn't get a message that it built correctly when I built it, so I think
> something went wrong as I got the following errors near the end of my
> failed
> postgis build:
> make[2]: Leaving directory `/home/zonabili/postgis-2.0.0SVN/raster/rt_pg'
> make -C loader
> make[2]: Entering directory `/home/zonabili/postgis-2.0.0SVN/raster/loader'
> /bin/bash ../..//libtool --mode=link gcc -g -O2  -fPIC -DPIC  -Wall
> -Wmissing-pr
> ototypes -I../rt_core -I/home/zonabili/postgis-2.0.0SVN/liblwgeom
> -I/usr/includ
> e/gdal -I/usr/local/include raster2pgsql.o ../rt_core/librtcore.a
> ../rt_core/lib
> rtcore.a /home/zonabili/postgis-2.0.0SVN/liblwgeom/.libs/liblwgeom.a
> -L/usr/lib
> -lgdal1.8.0 -L/usr/local/lib -lgeos_c -lm -o raster2pgsql
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I../rt_core
> -I/home/zonabili/
> postgis-2.0.0SVN/liblwgeom -I/usr/include/gdal -I/usr/local/include
> raster2pgsql
> .o -o raster2pgsql  ../rt_core/librtcore.a
> geom/.libs/liblwgeom.a -L/usr/lib -lgdal1.8.0 -L/usr/local/lib -lgeos_c -lm
> /home/zonabili/postgis-2.0.0SVN/liblwgeom/.libs/liblwgeom.a(lwgeom_geos.o):
> In f
> unction `LWGEOM2GEOS':
> /home/zonabili/postgis-2.0.0SVN/liblwgeom/lwgeom_geos.c:319: undefined
> reference
>  to `GEOSGeom_createEmptyPolygon'
> In f
> unction `lwgeom_sharedpaths':
> /home/zonabili/postgis-2.0.0SVN/liblwgeom/lwgeom_geos.c:1024: undefined
> referenc
> e to `GEOSSharedPaths'
> In f
> unction `lwgeom_snap':
> /home/zonabili/postgis-2.0.0SVN/liblwgeom/lwgeom_geos.c:961: undefined
> reference
> to `GEOSSnap'
> v collect2: ld returned 1 exit status
> make[2]: *** [raster2pgsql] Error 1
> make[2]: Leaving directory `/home/zonabili/postgis-2.0.0SVN/raster/loader'
> make[1]: *** [rtloader] Error 2
> make[1]: Leaving directory `/home/zonabili/postgis-2.0.0SVN/raster'
> make: *** [all] Error 1
> The JSON-C module was also a problem, as all they say to do with it is
> untar
> it and /.configure make it. but I feel like there is probably more that I
> need to do.
> I am really getting frustrated with this as I feel that I am so close, but
> keep hitting insurmountable obstacles where I have no clue what to do.
> I would greatly appreciate anyone who could help fix these flagrant errors
> and help me navigate this truly hellish installation process! I would be
> willing to uninstall everything and start from the beginning, although I
> don't actually know how to uninstall the geos because I had to build them
> from source and not apt-get!
> I am also new to linux (I finally just figured out how to get postgis 2.0
> installed on my windows laptop!) so please be as descriptive as possible.
> Thanks in advance, as this has been a huge headache for me!
> http://old.nabble.com/Installing-a-fully-functional-PostGIS-2.0-on-Ubuntu-Linux-GEOS-GDAL-issues-tp33035173p33035173.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111225/174bd117/attachment.html>
