[postgis-users] Querying geometries with different srid
Farrukh Najmi farrukh at wellfleetsoftware.com
Fri Jan 14 06:55:31 PST 2011
BTW, using nested SELECT did not work either as shown in follow query:
SELECT * FROM GeometryValueType gvt WHERE
     ST_SRID(gvt.geometry) = 4326 AND gvt.id IN (
       SELECT gvt1.id FROM GeometryValueType gvt1 WHERE
         within(gvt1.geometry, ST_GeomFromText('POLYGON((-100 0, 0 0, 0
100, -100 100, -100 0))', 4326)) = true
It again gives the "Operation on mixed SRID geometries" error :-(
It seems to me that surely this should be doable. If it is not doable,
do folks think that is an issue that should be tracked?
On 01/14/2011 09:49 AM, Farrukh Najmi wrote:
> Hi Ture,
> Thanks for the advice. Unfortunately WITH is not supported in postgres
> 8.3. So I could not try it out.
> Any other ideas?
> On 01/14/2011 12:38 AM, Ture Pålsson wrote:
>> 2011/1/14 Farrukh Najmi<farrukh at wellfleetsoftware.com>:
>>>> --Gives Error: Operation on mixed geometries
>>>> SELECT * FROM GeometryValueType gvt WHERE ( ST_SRID(gvt.geometry) =
>>>> 4326
>>>> AND
>>>>   within(gvt.geometry, ST_GeomFromText('POLYGON((-100 0, 0 0, 0
>>>> 100, -100
>>>> 100, -100 0))', 4326)) = true )
>> Does SQL guarantee left-to-right evaluation and short-circuiting of
>> AND checks the way that C does? I must confess I have no clue.
>> However, if it doesn't, that might be what's causing your headaches.
>> I'd try moving the SRID filter into a WITH construct or a sub-select
>> just to see what happens:
>> WITH filteredgeom AS (
>>    SELECT * FROM gvt WHERE ST_SRID(geometry) = 4326)
>> SELECT * FROM filteredgeom WHERE within(geometry, ...) ;
>> Probably lots of syntax errors (haven't had breakfast yet) but you get
>> the idea...
>>    -- Ture
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Regards,
Farrukh Najmi
Web: http://www.wellfleetsoftware.com
