[postgis-users] Querying geometries with different srid
Farrukh Najmi farrukh at wellfleetsoftware.com
Fri Jan 14 07:07:56 PST 2011
I have created a ticket in issue tracker for this issue here:
http://trac.osgeo.org/postgis/ticket/771
On 01/14/2011 09:55 AM, Farrukh Najmi wrote:
> BTW, using nested SELECT did not work either as shown in follow query:
> SELECT * FROM GeometryValueType gvt WHERE
>     ST_SRID(gvt.geometry) = 4326 AND gvt.id IN (
>       SELECT gvt1.id FROM GeometryValueType gvt1 WHERE
>         within(gvt1.geometry, ST_GeomFromText('POLYGON((-100 0, 0 0, 0
> 100, -100 100, -100 0))', 4326)) = true
> It again gives the "Operation on mixed SRID geometries" error :-(
> It seems to me that surely this should be doable. If it is not doable,
> do folks think that is an issue that should be tracked?
> On 01/14/2011 09:49 AM, Farrukh Najmi wrote:
>> Hi Ture,
>> Thanks for the advice. Unfortunately WITH is not supported in
>> postgres 8.3. So I could not try it out.
>> Any other ideas?
>> On 01/14/2011 12:38 AM, Ture Pålsson wrote:
>>> 2011/1/14 Farrukh Najmi<farrukh at wellfleetsoftware.com>:
>>>>> --Gives Error: Operation on mixed geometries
>>>>> SELECT * FROM GeometryValueType gvt WHERE ( ST_SRID(gvt.geometry)
>>>>> = 4326
>>>>> AND
>>>>>   within(gvt.geometry, ST_GeomFromText('POLYGON((-100 0, 0 0, 0
>>>>> 100, -100
>>>>> 100, -100 0))', 4326)) = true )
>>> Does SQL guarantee left-to-right evaluation and short-circuiting of
>>> AND checks the way that C does? I must confess I have no clue.
>>> However, if it doesn't, that might be what's causing your headaches.
>>> I'd try moving the SRID filter into a WITH construct or a sub-select
>>> just to see what happens:
>>> WITH filteredgeom AS (
>>>    SELECT * FROM gvt WHERE ST_SRID(geometry) = 4326)
>>> SELECT * FROM filteredgeom WHERE within(geometry, ...) ;
>>> Probably lots of syntax errors (haven't had breakfast yet) but you get
>>> the idea...
>>>    -- Ture
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Regards,
Farrukh Najmi
Web: http://www.wellfleetsoftware.com
