[postgis-users] Geocoding Issues with Route, ##-## house numbers; upgrade questions
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jul 28 12:14:23 PDT 2011
On 7/28/2011 2:31 AM, Paragon Corporation wrote:
> Steve,
> Thanks.  I would be interested in this once I get to tackling street
> numbers, but battling some other issues at the moment on various other
> fronts so I'm a bit distracted and only focusing on low hanging fruit aside
> from the critical stuff I'm working on.
Regina,
No problem, when you want to tackle this let me know. I have down a lot
of work on this already. I attached a zip file with the distinct left
side patterns. These are no quite the abstract patterns I mention below
but they are useful. I can also look into generating those patterns, but
first I think we need to think the problem through.
The way I generated these format strings was to classify the numbers in
the from-to ranges and identify which part of the complex number was
varying over the length of the segment. Then saved that part as the
from-to address numbers for that range and saved the formatting to
reconstitute the whole number. This was used in my reverse geocoder and
does not exactly work for geocoding but I think a similar trick can be
devised for geocoding. This has a basic assumption that only one part
can vary otherwise I'm not sure how one would interpolate a distance
over the range. You will notice toward the end of the list that there
are two {} escape patterns which means there are two components that are
varying over the range so those are probably broken.
Anyway, give me a shout when you have time to look into this and I'm
happy to discuss it with you and see if we can work out a strategy that
will work for geocoding.
Thanks,
   -Steve
> Thanks,
> Regina
>> This is a harder problem because there are a great many different house
>> number range patterns and most geocoders assume only simple house
>> numbers. This problem is compounded by the fact that you need to match
>> even if one or more of the components are missing. For example, if the
>> street has an address range does the 112 or the 31 component vary over
>> the range?
>> Regina, If you want all the various patterns I have what so other docs
>> that have all the patterns described. We might also want to load all the
>> Tiger data and run a pattern classifier on all the Tiger house numbers.
>> We could convert the actual house number into something like:
>> n - a string of digits
>> a - a string of letters
>> p - punctuation
>> s - space(s)
> postgis-users mailing list
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110728/ea4a852a/attachment.bin>
