[postgis-users] st_transform crashes
Paragon Corporation lr at pcorp.us
Sat Jul 30 17:42:59 PDT 2011
Bryan,
I guess it could be the proj library we have the windows build built with
doesn't support some new feature required by martian spatial refs.
We were planning to release PostGIS 2.0 with the newer proj library which
might resolve your issues.  Would be interesting to see if someone with a
newer proj runs into the same issue with your dataset.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bryan
Hempen
Sent: Saturday, July 30, 2011 6:17 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] st_transform crashes
@Leo and Regina:
"POSTGIS="2.0.0SVN" GEOS="3.3.1dev-CAPI-1.7.1" PROJ="Rel. 4.6.1, 21 August
2008" LIBXML="2.7.8" USE_STATS"
"PostgreSQL 8.4.8, compiled by Visual C++ build 1400, 32-bit"
I am using Windows XP.
@Josh Jordan:
I had some invalid geometries in the table but fixed them now.
   select count(*) from alldata where ST_IsValid(the_geom) = 'f';
returns 0. However, the database still crashes.
Thanks for the input so far. Any other ideas?
Kind regards,
Bryan
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
