[postgis-users] st_transform crashes
Paragon Corporation lr at pcorp.us
Sun Jul 31 10:24:01 PDT 2011
Bryan,
Not sure if you got the cc to the bug report I posted.
The issue seems to be that the:
http://spatialreference.org/ref/iau2000/49910/
Is lacking a proj4text -- PostGIS pretty much ignores everything in the
spatial_ref_sys except the proj4text column.  The rest of it is just
metadata for other tools.
So you need to figure out the comparable proj4text for this -- assuming
there is one.
It is a bug though that PostGIS even allows entries into the spatial_ref_sys
without coughing an error when proj4text is empty.
Thanks,
Regina
http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Bryan Hempen
> Sent: Saturday, July 30, 2011 6:17 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] st_transform crashes
> @Leo and Regina:
> "POSTGIS="2.0.0SVN" GEOS="3.3.1dev-CAPI-1.7.1" PROJ="Rel. 4.6.1, 21 August
> 2008" LIBXML="2.7.8" USE_STATS"
> "PostgreSQL 8.4.8, compiled by Visual C++ build 1400, 32-bit"
> I am using Windows XP.
> @Josh Jordan:
> I had some invalid geometries in the table but fixed them now.
>    select count(*) from alldata where ST_IsValid(the_geom) = 'f';
> returns 0. However, the database still crashes.
> Thanks for the input so far. Any other ideas?
> Kind regards,
> Bryan
> postgis-users mailing list
