[postgis-users] insert to database - error
Robert Buckley robertdbuckley at yahoo.com
Tue Mar 1 23:19:28 PST 2011
Ubuntu 10.04
geoserver-2.0.2
postgresql 8.4
postgis
I am experiencing the following:
I can edit a postgis database geometry in Quantum GIS but I can´t "insert" into
a postgis table inserted with shp3pgsql. ( I used the opengeo-suite windows
version to upload the shp)
my error is here message is here ..
http://permalink.gmane.org/gmane.comp.gis.geoserver.user/26390
After days of scratching around the forums and reading this...
http://lists.osgeo.org/pipermail/openlayers-users/2010-March/016801.html
..I  decided to do the same a make a simple table in postgis  - 1 x "id"
column  (type - integer, primary key, NotNull) and 1 x "the_geom" column  ( type
- geometry)
I loaded it into geoserver and was able to start editing immediately!!!!
Is it then something to do with the constraints inserted by shp2pgsql?..( I
removed all of them one by one and tested the insert, but it still didn´t work)
Possibly do to with the GID column? I ccan´t remove this column without breaking
the geometry structure.
Idon´t understand what the problem is with the table imported from a shapefile
using shp2pgsql
yours,
Robert
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110302/6c4903de/attachment.html>
