[postgis-users] Read WorldClim gridded data in QGIS
Brent Fraser bfraser at geoanalytic.com
Sun Oct 16 08:41:51 PDT 2011
You could try posting the question to the GDAL or QGIS list.
Best Regards,
Brent Fraser
On 10/16/2011 9:14 AM, uyen dang wrote:
> Hello, have any one try to read WorldClim gridded data in QGIS?
> I first convert the generic grid format to ESRI Ascii using DIVA-GIS
> <http://www.worldclim.org/formats>, but i can not get up the color map.
> Following is Information that i get from the gdalinfo command :
> Driver: AAIGrid/Arc/Info ASCII Grid
> Files: /media/Logiciel/telechargement/tmean_esri/tmean1.asc
> Size is 8640, 3600
> Coordinate System is `'
> Origin = (-180.000000000003013,90.000000000000000)
> Pixel Size = (0.041666666666667,-0.041666666666667)
> Corner Coordinates:
> Upper Left  (-180.0000000,  90.0000000)
> Lower Left  (-180.0000000, -60.0000000)
> Upper Right ( 180.0000000,  90.0000000)
> Lower Right ( 180.0000000, -60.0000000)
> Center      (  -0.0000000,  15.0000000)
> Band 1 Block=8640x1 Type=Int32, ColorInterp=Undefined
>   NoData Value=-9999
> Do you have any suggestions ?
> Thanks.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111016/5d27eee5/attachment.html>
