[postgis-users] shp2pgsql - how to continue when error occurs
Muhammad Imran imranserver at yahoo.com
Tue Jan 3 05:16:40 PST 2012
Hi Lauri,
This is becuase PG doesn't support INSERT IGNORE/REPLACE (as in MySQL or Oracle).
-Imran
--- On Tue, 1/3/12, Lauri Kajan <lauri.kajan at gmail.com> wrote:
> From: Lauri Kajan <lauri.kajan at gmail.com>
> Subject: Re: [postgis-users] shp2pgsql - how to continue when error occurs
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Date: Tuesday, January 3, 2012, 4:16 PM
> Thanks Imran,
> That was also in my mind, but thought I could have less
> steps to
> complete the import.
> -Lauri
> On Tue, Jan 3, 2012 at 11:50 AM, Nithya lakshmi
> <lakshmi.nithya18 at gmail.com>
> wrote:
> > how to use Rtree in postgis
> > On 1/3/12, Muhammad Imran <imranserver at yahoo.com>
> wrote:
> >> Hi Lauri,
> >> 1- Disable or remove unique key (UK) on table.
> >> 2- Import data using shp2pgsql
> >> 3- remove duplicate rows using SQL
> >> DELETE
> >> FROM  sometable
> >> WHERE         someuniquekey NOT IN
> >>       (SELECT
> MAX(dup.someuniquekey)
> >>         FROM
>  sometable As dup
> >>         GROUP BY      dup.dupcolumn1,
> dup.dupcolumn2, dup.dupcolum3)
> >> (http://www.postgresonline.com/journal/archives/22-Deleting-Duplicate-Records-in-a-Table.html)
> >> 4- Enforce UK
> >> -Imran
> >>> Subject: [postgis-users] shp2pgsql - how to
> >>> To: postgis-users at postgis.refractions.net
> >>> Date: Tuesday, January 3, 2012, 1:18 PM
> >>> Hi all,
> >>> I'm trying to merge multiple shapefiles to
> postgis table. I
> >>> know that
> >>> there is some duplicates in different files.
> >>> I thought that I could just check
> duplicatiness when
> >>> loading shapes
> >>> with shp2pgsql.
> >>> So I first created an empty table and added a
> unique
> >>> constraint to the
> >>> field that I know to be unique with non
> duplicate records.
> >>> But now when shp2pgsql tries to insert first
> duplicate
> >>> record and
> >>> error occurs it stops and won't load any
> records.
> >>> Is there a way to continue when "key already
> exists" -error
> >>> occurs?
> >>> I read that in shp2pgsql that comes with 2.0
> it has -e
> >>> parameter that
> >>> loads each record invidually. Is this the only
> way to go?
> >>> Don't like
> >>> that cause I have 13GB shape files. And I
> would like to use
> >>> Dump
> >>> dormat.
> >>> Thanks
> >>> -Lauri
> >>> postgis-users mailing list
> >>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> >> _______________________________________________
